Results 1 to 10 of 19
    Question How do you tell difference-semi vs full floating rear azles?
    Need to replace rear wheel bearings on 2000 silverado 4x4 ext. Cab w/short bed.
    Manual doesn't tell you how to tell tbe difference.
    Can anyone help?
    Thanks,
    Ben
    Quote Originally Posted by Bherr View Post
    Can anyone help?
    Thanks,
    Ben
    what you have is the eaton locking differential. most have the 3.73 gears. 5.3L engine .
    you must remove the axles and install the bearings. simple job along with new seals.
    with this I would wash [mineral spirits]out the gear box and make sure that the wheel bearing drain back holes on the rear cover are open. they only used one type of axle.
    this is for the 8.5 ring gear on the 1500 http://www.autozone.com/autozone/par...uestid=1225827
    " other bearings would be required with the 9.5 ring gear."
    Former Member
    Apr 2012
    Reading, PA
    Can anyone help?
    Thanks,
    Ben
    Look at the hub...if there is a ring of bolts in the center of the wheel studs, its a full floater. They are almost always eight-lug (or more), unless its antique. The attached picture (courtesy of someone else) is a full floating axle, see the protrusion in the center of the wheel studs?
    They are typically found on 2500s and 3500s, while the semi-floats are found on the 1500s.
    Can anyone help?
    Thanks,
    Ben
    IIRC, only the 2500 and 3500 trucks have the option of a full floating axles. From your post it sounds like you have a 1500 so no floating axles.
    Mods:
    Advent OGM1 Navigation
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    Flowsound 40 Muffler
    Chrome Tailgate Handle Cover
    TonnoPro HF-155 Tonneau Cover
    Former Member
    Apr 2012
    Reading, PA
    I was going to say that, but that darn 1500 "HD" drops in there...and I can't remember if it had the big semi-float or a Corp 14-bolt...
    Thanks J cat! that's what I thought but wanted to make certain.
    Ben
    Quote Originally Posted by steved View Post
    From what I've read, the Silverado 1500HD only came in a 6'6" bed. The OP said short bed (can we assume 5'9").
    Not if it's a 2000. The crew cab 1500 didn't exist then. a 2000 short bed would be 6'6".
    Former Member
    Apr 2012
    Reading, PA
    I bet most owners don't distinguish between the short beds, its either a long bed (8-foot) or a short bed (everything else under 8-foot).
    And I am pretty sure the one 1500HD I saw (only one of two I have ever seen) was an long bed...but that was a while ago, and it was only a "GM made a 1500HD?" thought at that time...
    the 1500 HD crew cab came out in 2001 I think. I know a person who got one in the fall of 2000.
    the 2000 ext cab came out with 3 then 4 doors , but not regular doors like the crew cab.
    I have the 2000 silverado sales literature.
    In march 2000 I ordered my 2000 ext cab 4 door . in jan of 2000 is when they started making the 4 door model. this was something I learned was going to happen so I waited to see how it would look,before ordering.
    In 2000 you could get the ext cab 4 door model with the long bed . I got the short bed. the long bed makes it a very long truck for my uses. 247 inches is the length
