ok.
so money's tight but i can't not have my ipod.
does anyone know if a 2007 STOCK headunit (with aux input) will fit and work in my 2005?
thanks guys!!!
Equinox Parts
Which vehicle do you have? It depends on whether or not the model year has changed much between then. If it's a different platform, then most likely it won't work.
I'd suggest checking out PAC or other companies for adapters that'll work with your current HU and give you the ipod or aux inputs you're looking for. Much cheaper and easier.
2009 GMC Sierra Denali AWD
I know that my '04 doesn't have the "aux" input needed for using "i-pod". I was told that if your radio has "XM" capacity you can get the interface from after market supplier. I use the cassette interface to play my i-pod through the radio. Works well for me, good luck!
2010 Z/71 Colorado C/C
Black 4X4 w/5.3L V8
2007 Winnebago Adventurer
w/8.1L Chevy & Allison 6spd.
Canyon Lake, Texas
I just installed this today it had two RCA inputs
I got an stereo Y-splitter and i'm able to plug anything into this sucker
the unit itself is plug and play install ..got it from crutchfield.com
under aux inputs
04 Tahoe LT 5.3L stock MSD 8.5mm Wires
Gigbson Duels Straight Exhaust, Parrot 3100 Bluetooth
K&N 77 Series CAI, Sirius Radio
De-badged, Valet Dei remote start
5000k HID -Higherlevelauto.com
Federal 100watt air horn
Unfortunatley it will not work, the software inside the radio is newer than what is in the car, it wouldn't recognize it/support it and probably wouldn't even power up. Maybe even self distruct ( not really)![]()
Live by one rule: Make it black, make it low, and make it a GM!
I have a 2005 nox. i am also interested in adding a mp3 connection as well as hooking up my sirius directly.
Tom -
2005 Suburban 4x2
2005 Equinox LT AWD
Bookmarks
