    Default Fuel Pressure Regulator bad?
    I have an 87 5.7 TBI GMC Burban.
    I am current having a very ruff idle and cold start issue. The cold start has been going on for some time and I have done a few things already. Today the ruff idle started and it is also blowing black smoke and wants to stall. It runs when driving pretty well. However when you get to a stop sign the engine wants to shoot out of the hood. It idles very high and if I rev the engine in park the idle will go up and stay up.
    Now I just did the spark plugs today. Which where bad but was not the issue. The timing has been recently set and the pcv was replaced. Also the coolent temp sensor was also replaced.
    I am wondering if this could possibly be my fuel pressure regulator? up until today it never blew black smoke before. It was running 100% perfect yesterday. With just the cold start issue.
    Any thoughts?
    i say you got a vaccum leak. chech all the vac lines. you might want to spray some carb cleaner on each line and if the idle changes that is your leak. i bet you can hear a leak as large as you seem to have.....mike
    Michael Collins
    1993 4X4 Suburban
    many other toys as well
    Yes you can.. There is a ticking noise. That just got louder that sounds like a vac leak. I fixed a small one awhile ago but I am guessing that was not the right one.
    You can check if the fuel pressure regulator is bad by taking off the vacuum line, If the line is wet with fuel it is bad. I had cold start problems and response problems, my regulator was bad and it starts up like new now that i replaced it
  1. fuel pressure regulator
    By kspeng in forum GM Powertrain
    Last Post: 07-14-2010, 04:56 PM
  2. fuel pressure regulator ???
    By drradon in forum Performance & Fuel
    Last Post: 05-20-2009, 08:55 PM
  3. fuel pressure regulator?
    By script0207 in forum General Chevy & GM Tech Questions
    Last Post: 04-30-2009, 04:13 PM
  4. fuel pressure regulator...
    By Cros89 in forum Performance & Fuel
    Last Post: 12-05-2008, 09:06 AM
  5. Fuel Pressure Regulator
    By Soonerfan in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 07-19-2007, 07:01 PM
