GM Truck Club
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
    Default Captiva Changing Gears ~ 15K Miles, and already an issue! (2012 Chevy Captiva V6 FWD)
    Well, I was in stop and go traffic the other day (temps were normal) but speed was right around where 1st changes into second and vice versa. I noticed that when the transmission upshifted from 1st to 2nd, it would clunk and jerk the whole vehicle. ell after a while of stop and go, i just figured it was just a quirk I need to get used to. After about 20-30 mins of this traffic, I would lightly press the gas to move up and when the transmission shifted from 1st to 2nd, it revved up, almost like it was in neutral, then chirped the tires when it caught second gear. (dealer could not replicate, and says its fine)
    Any thoughts?
    Did you check fluid level?
    Ray
    '09 Avalanche LTZ - Black
    '05 Envoy XL (sold)
    I guess I made the 1st mistake of being a mechanic. Never trust that the dealership has checked all that. I'll be sure to do that on my off day.
    As a brand new car that's under warranty the dealer should listen to you and try to find and fix the problem.
    1996 Chevy Tahoe LT 5.7L V8 4X4 205,000+ miles. Built proudly at Janesville Assembly in Janesville, Wisconsin
    Basic mods: Lights all over, bunch of electrical work, and a couple cooling mods.
    Check out my other mods in My Garage: http://www.gmtruckclub.com/forum/sho...t-Tahoe-4-Door
  5. #5
    I'm about to just say **** it and try to break it. Hard to ignore a trans missing an entire gear.
  6. #6
    Since you have a 2012 Captiva, I assume you are still under 36K miles? If yes, then take it to the Chevrolet dealer and they'll diagnose and fix the problem.
    2013 Silverado LTZ White Diamond Crew Cab
    Mods:
    Advent OGM1 Navigation
    Husky Liners GearBox Underseat Storage
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    Flowsound 40 Muffler
    Hypertech Max Energy Tune (only top end limiter removed and AFM disabled)
    Chrome Tailgate Handle Cover
    TonnoPro HF-155 Tonneau Cover
    WeatherTech Front and Rear Splash Guards
    Husky Liners X-Act Contour Floor Liners
    WeatherTech Side Window Deflectors
  7. #7
    [QUOTE=Camaro69car;579712]Well, I was in stop and go traffic the other day (temps were normal) but speed was right around where 1st changes into second and vice versa. I noticed that when the transmission upshifted from 1st to 2nd, it would clunk and jerk the whole vehicle. ell after a while of stop and go, i just figured it was just a quirk I need to get used to. After about 20-30 mins of this traffic, I would lightly press the gas to move up and when the transmission shifted from 1st to 2nd, it revved up, almost like it was in neutral, then chirped the tires when it caught second gear. (dealer could not replicate, and says its fine)
    Not to be rude.
    I'm going to make them ride in the truck with me when I do it. just so they can see.
    if they say its fine, then i'm going to find a way to break it.
    checked the fluid level today. cold engine, on flat surface, and the fluid level was 1/8" off being dead center. just a tiny bit lower than perfect.
    Any thoughts?
  8. #8
    My thought: the problem is that the dealer could not replicate the problem. You as the one who drives it all the time, are in a better position to know when it acts up and when it doesn't. In many ways, I would agree with the "take him on a ride" approach. Maybe start with, "I recognize this problem is intermittent, how did you test it last time? ___ Those aren't the kind of conditions/situations where I experience the problem. It only seems to act up when _____. Would it be helpful if me and your technician went out together so I can show him the symptoms and the driving situation(s) that trigger the symptoms."
    '98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
    '92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
    "My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
  9. #9
    Camaro69car,
    I understand your frustration with the dealership not being able to duplicate an issue you are experiencing with your vehicle. I am happy to locate another dealership in your area for a second opinion. If interested, I could even set up the appointment for you. Please private message if I can be of any assistance.
    Regards,
    Jennifer T.
    GM Customer Care
  10. #10
    I appreciate the offer Jennifer, However I already have an appointment for this weekend at a different dealership. I would like to message you regarding some warranty questions.
