Results 1 to 10 of 12
    Default Chevy 4X4 ... for real or not?
    A guy at work who likes to brag says my Chevy HD is not really true four wheel drive and his toyota is. He says if one wheel gets stuck I will not be able to get out, while his Toyota will never get stuck?? Or if I lifted 1 wheel off the ground the others would not do anything.
    2011 2500 HD towing package with locking differential 4:10 axle
    2011 Silverado 2500HD 4X4
    2013 CB1100
  2. Likes Steve liked this post
  3. #2
    Is his Toyota equipped with the electronic locking rear diff? Can I assume your truck has a typical two speed, locking transfer case (2H, 4H, 4L)?
    With those two assumptions made, especially in low range where speeds are low, you effectively have 3 wheel drive (assuming the G80 works as advertised) -- one front and both rear wheels. If he has a locking rear, too, then he effectively has 3 wheel drive as well - one front and both rear.
    In terms of who will get stuck under what conditions, I expect the two are near equals. Your 2500 is likely heavier than his Toyota -- sometimes that will be an advantage, sometimes a disadvantage. The difference between the two trucks will probably be more about who's driving and how well he picks his line that what badge is on the truck's grill.
  4. Thanks Steve thanked for this post
  5. #3
    You have a locker so you'll never get stuck so he is very wrong, I think he's under the impression you have AWD not 4WD, but still gm AWD is designed to lock up when needed. Just use your smart phone (if you have one) go on YouTube and search Eaton locking diff and show him the videos.
  6. #4
    First off what model Toyota does he have?
    If its a truck the best he has is equal to yours on drive wheels unless he installed a front locker.
    Which I doubt since IFS eats cv's and pinion/gears when combined with a locker.
    Some earlier model land cruisers had locking center, front, and rear diffs which would crawl out of a lot of stuff, but not everything.
    obviously hes not very experienced if he thinks lockers will make his truck unstickeable.
    As an off roader it sounds like he has lots to learn.
  7. Likes rileyjr16, Steve liked this post
  8. #5
    Sounds like he's a 16 year old in daddy's truck.
    Current:
    Future:
    US Navy Sailor :sign0011:
  9. Likes Steve liked this post
  10. #6
    Quote Originally Posted by johnnymac View Post
    Send him my way! I will get him stuck!
  11. #7
    Oct 2010
    Cobourg, Ontario, Canada
    awesome come Back Pikey...............make sure you post the Video if he shows up LOL.
    Brian from Canada.....huh.just a 2WD owner ....oh well !!
    Silverado Crew.....4.8 L
  12. #8
    GM's Eaton vs other diffs
  13. Likes Steve liked this post
  14. #9
    But of course in the video he doesnt discuss the fsct that with an open or LSD you can kick in some park brake snd get the power to transfer to the other wheel.
    But then he was only selling the eaton, not showing how to overcome a problem.
  15. #10
    Yeah, there are ways to get around some of the issues that these products were designed to fix, but in general hard to discount how effective of a presentation this was for what most drivers are going to do ... they're gonna floor it when they feel themselves slipping.
    Steve
    10 Chevy Traverse LT AWD
