Results 1 to 6 of 6
    Sr. Apprentice ODogg is an unknown quantity at this point
    Nov 2006
    Default 3" drop on my 2007 Yukon...
    What will this entail on my end? I've looked at this Eibach Pro Kit...
    http://www.autoanything.com/suspensi...&from_search=1
    I'm not sure if this is all I'll need or not...But, for those of you who have done it...will it require a lot of mods due to my 24" wheels?
    I know there will be rub on the wheel well liners...can these simply be removed?
    Thanks!
    Nov 2006
    Perhaps this should've been posted on the aftermarket forum...
    Legend
    Pete95Sierra is a name known to all
    Jan 2008
    Morristown, NJ
    nope, your in the right place. the wheel well liners im assuming are plastic so they can be cut out if your tires rub. even if they are metal they can be cu out also. the 24's hopefully should fit ok as long as you get the right size tires
    PETE
    95 GMC Sierra 2500
    3" Body Lift, 33" Goodyear MTR's
    5.7L 350 TBI Edelbrock SDT Exhaust, Flowtech Headers, K&N Intake
    Sold :(
    1999 Jeep Cherokee, 3" Rustys lift, 33" BFG MT's, locked, armored: Rolled :(
    2000 Jeep Grand Cherokee Limited. K&N Intake, Custom Kolak Exhaust
    Contact this GMTC Moderator for any problems or questions you may have
    Join the GMTC Facebook Group!!! Join Here
    Nov 2006
    Quote Originally Posted by Pete95Sierra View Post
    The tires are 305-35's...pretty much the standard, from what I understand. Also, the liners are plastic, but I'd like to leave cutting to a minimum...perhaps a heat gun and a rubber mallet?
  5. #5
    Legend
    Jan 2008
    Morristown, NJ
    actually that heat gun trick may work ive never heard of anyone doing this. as for the tire size they should fit fine
    PETE
    95 GMC Sierra 2500
    Sold :(
  6. #6
    Sr. Mechanic asstda2b is an unknown quantity at this point
    Aug 2005
    Los Angeles, CA
    The other thing that you have to consider is when you lower a truck, depending on the wheel size you may not be able to turn the wheel compltely either direction. on my sliverado, i only had 18 wheel but the drop was a 4/6 and i had to go to a friend and have them do some welding on the front end. you will eat the crap out of your wheel on the back side, as when you turn the wheel all the way you are rubbing metal against the wheel and over time grinding it away. just a note, you may not have this problem.
    STEPHANIE
    Los Angeles, California
    2004 Trailblazer (DJM drop kit, K&N air intake, 18' Kaotic Wheels, full system with Sirius and also custom
    sub installed for cleaner look, tint all the way around, JBA exhaust...still looking for more to do)
    Had until it was stolen:
    1990 lowered Chevy Silverado
    Also Have:
    2002 Chevy Suburban
    1992 Chevy S-10
    1955 Chevy Bel Air
    sad to say: also a 1991 Ford F-250
Similar Threads
  1. 95 Yukon "thunk" when coming to a complete stop
    By 95YGT in forum General Chevy Tech Q&A
    Last Post: 07-25-2011, 09:11 AM
  2. What Will My MPG Drop with 4" Lift & 35" Tires?
    By TexAg95 in forum Wheels & Tires
    Last Post: 03-20-2010, 08:22 PM
  3. 2"/4" drop pics please
    By mashburn in forum Lifted & Offroad Suspension
    Last Post: 05-14-2009, 07:42 PM
  4. 95-99 Tahoe/Yukon Rear Drop Leafs
    By Bigg G in forum For Sale & Wanted to Buy
    Last Post: 05-12-2009, 09:59 PM
  5. 3" drop on 2007 Yukon
    By ODogg in forum Chevy Truck Accessories
    Last Post: 06-17-2008, 10:36 PM
