Results 11 to 20 of 21
    Probably be ok with diesel from a few years back, but the new diesel is supposedly not as lubricating with the low sulfur. Probably better off using an additive if you want to clean out your engine and add lubrication.
    Source:
    http://www.dieselpowermag.com/tech/f...t/viewall.html
    Charles 02 z71 Cladded Avy
    Mods: eBay k&n Intake, highflow magnaflow cats & y pipe, 6" FabTech lift, 35" Pro Comps, Superchips #2715, SnugTop, 4.56's, MOOG front end
    Wishes: LQ4 + a beefed up 4L60E
    Back in the day ATF was ok. But, I have heard that it can mess up your cats and O2 sensors. I don't know if it is true or not. I run TC-W3 2 cycle marine formula in every tank with a 5 gallon to 1 ounce ratio. It is said that it lubes and cleans injectors, fuel pump, and valves. I have been running it approx 6 months and have seen an increase from between 13.5-15.2 mpg to a solid and consistent 17.4 mpg in the city. Not to mention a smoother idle
    This is what I do ^^^^^
    I have heard of the diesel thing too but dont remember the mix ratio.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    Ethanol is a natural cleaning agent, so you don't really need to worry about adding diesel as a means to clean the fuel pump and injectors. Petroleum is also a natural lubricant, and how the fuel pump is normally lubricated. If you want additional cleaning and lubrication, then a standard cleaner/lube mix-in like the ones from Lucas or STP will generally suffice. If you want to add additional lubrication, to make up for the loss of any lubrication in a 10% ethanol mix, or with E85, then adding in some "top end lube" wouldn't be a bad idea. All the drag racers running methanol or ethanol, have to run it to help out with lubrication as the alcohol doesn't lube as well as gasoline does.
    Quote Originally Posted by dobey View Post
    This is true. But, ethanol also causes corrosion. You are correct that you can use a STP or Lucas additive. But, TC-W3 2 cycle is much cheaper to use. I bought a gallon of it for $22. I have used it with every fill up for the last 6 months and I am barely half thru the gallon. You can get it cheaper if you don't buy the synthetic. I think that I saw somewhere that walmart has it for $14 a gallon.
  5. Likes Sierraowner5.3 liked this post
  6. #15
    Yeah, on first thought there is something to this ... but I wouldn't do it to any vehicle of mine.
    @tbplus10 is right. Diesel and some of the fuel system cleaners do have a common origin, but I would want to talk to a chemical engineer before I would recommend this. Plus, why not just get one of the tried-and-true cleaners like SeaForm or RXP instead of trying to figure out the proper way to dilute it?
    Steve
    10 Chevy Traverse LT AWD
  7. #16
    Quote Originally Posted by kinson33 View Post
    Source:
    Gasoline used to have decent lubricating qualities too, before the govt. required unleaded fuel.
  8. #17
    Giving that a shot, off to walmart I go! Any brand preference for the two of you that already do this?
  9. #18
    I use pensoil full synthetic marine formula.
  10. #19
    Jun 2006
    Marvel mystery oil is supposed to a bit like heavier diesel
    read that somewhere
    The diesel in gas-real oldschool
    2 gallons per tank-seems a bit high-
    probably would use less-maybe a pint or so per tank if I was going to do it
    EASIER to just use sea foam techron etc
    1998 suburban-
    1/2 ton
    199500 miles
    River
    Ridge,LA
  11. #20
    Maybe my figure was a little high. He said today that he never put over a gallon of it in his truck. I was young
    Current:
    Future:
    US Navy Sailor :sign0011:
