Results 11 to 19 of 19
    I don't believe any Silverado uses dexos2 grade oil. The gas engines require dexos1 and the Duramax requires CJ-4 oil.
    I checked the manual and it is DEXOS1, I was going from memory. The manual states GM DEXOS1 is a synthetic blend.
    Attachment 55223
    Quote Originally Posted by WorthFlorida View Post
    Attachment 55223
    I thought when you said your Silverado uses dexos2 that you had a Duramax engine.
    Mods:
    Advent OGM1 Navigation
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    Flowsound 40 Muffler
    Chrome Tailgate Handle Cover
    TonnoPro HF-155 Tonneau Cover
    Jun 2013
    I change my oil at 5-6k miles and always try to use decent filter. If we change oil filter every 5-6k miles then we never had any issues with vehicles..
    I change oil and filter every 4500 miles, but I also use my truck like a truck. I've tried just changing the filter at 3000 and topping off with fresh oil and changing all at 5000, but didn't really see much difference. Ultimately its all about where and how you drive, and what you use the truck for. I use mine like a two ton and drive it like a camaro.
    You have enemies? Good. That means you've stood up for something, sometime in your life.
    Winston Churchill
    Quote Originally Posted by rg79 View Post
    What kind of oil and filter do you use? Unless you are using conventional oil, 4500 miles is a bit too frequent.
    I was using valvoline 5/30 conventional, but have switched to valvoline 5/30 synthetic. I also use a 6.0 filter since its double the length. You can do that from 99-06, GM changed the filters in 07.
    With synthetic oil it is OK to go 6-9K miles between changes.
    Me personally I have never been a fan of using a different filter than the one that was designed to go on the vehicle. If GM could have gotten away with using a filter from an older engine, they would have.
  8. #18
    Jr. Apprentice Clunker's Avatar
    Jun 2011
    Central Texas
    I change my oil/filter every 6-7K miles. Use AC Delco filter and Mobile1 5-30 full synthetic. I've done this since I bought new in '08 and now at 80K miles with no problems.
  9. #19
    at 5k miles I change oil, filter, and tire rotation, every 10k i balance the tires in additon to a rotation, I use GM oil and filter, and nitro in my tires. Changing oil and filter at 5 k gives me that warm fuzzy confident feeling.
    Life is short compared to history
    Rick (summitwhite11)
