Results 1 to 9 of 9
    Default stumped after engine swap ~ 5.3 to 4.8 in 2006 Z71
    I changed out my 5.3 to a 4.8 in my 2006 z71 it will turn over but will not fire have already changed out coil packs any suggestions would be appreciated
    We might need more info on this one. Did you change the ecm? did you have it reprogrammed? How is the fuel pressure?
    Has got good fuel pressure. No didn't know I had to change the ecm also think security system may have faulted out because when I turned the key over lights went to flashing and horn honking
    Hopefully someone else can help here. I am pretty sure that the ECM control timing, fuel delivery, and a bunch of other things. I am going to move this thread into the power train sub forum to get you better results
    Quote Originally Posted by sheldon70 View Post
    I understand that you are looking for assistance in resolving your vehicle issue yourself and I might not be able to give you any technical advice. If you find that you cannot resolve this vehicle concern yourself, I am happy to assist with any general questions or concerns you may have.
    Regards,
    Jennifer T.
    GM Customer Care
    with the security light on the vehicle will not start. now I do not understand why an engine swap would cause the security to be activated.
    since the engine is cranking then I would measure the fuel pressure. engine swaps could mean many things . give details about the replacement engine . what you did to do with this swap ? engine come with manifolds intake exhaust/throttle body/same year or what year ? injectors /coils with engine or swapped stupid stuff like this .....
    @sheldon70 has the engine ever run in the truck?
    make sure your getting spark and fuel first off. and id look intom a pcm or a tune.... also what did u do a 5.3 to a 4.8???
    2004 gmc sierra ext z71 5.3
    PERFORMANCE...
    KB racing hot pipes 3.5" : 76mm turbo: 4l80e : Circle-d 2b multi disk :Walbro 400 : Racetronix Hotwire kit : TB coolant bypass : Nelson 91 Pcm : Tr 220 Cam : Brian Tooley double springs kit : Ls7 Lifters : Stage 3 heads : Custom Intake Manifold :80lb Injectors : Ported TB : 40k tranny cooler: Plx dm-100 gauge: Auto meter fuel and boost gauge:
    APPEARANCE...
    Custom Speedo : Leveling kit :Smoked led taillights and 3rd break light : Black projectors and fogs with hids : Blacked out grille : 33's on 16's : Clarion flip screen: sound que 12" subs: clerion 6x9's : Memhpis amps: Alpine componet set.
    Future mods... Detriot tru-trac, deviels own stage 2 meth kit, MORE BOOST!!!!!!!!!!!!!!
