Results 1 to 3 of 3
    Newbie 86burb is a glorious beacon of light
    Jun 2008
    Huntsville Ontario Canada
    Default '86 Burb diff. gear question
    Howdy..I'm new to this forum. I am looking for some advice.
    I have a 1986 4WD 10 series Burb in great shape. I have to replace the rear diff. gears..(broken tooth on the ring gear)
    Gear set is(3.42) 41-12, 8 1/2 " -10 bolt.
    I am having a hard time finding a good used set. A friend gave me a complete set of gears but it is a(3.08) 40-13.
    The front diff. is OK.. Should I keep looking for 3.42's or put the freebie 3.08's in and look for another set for the front? Which ratio is most common?
    The pinion on the 3.08's looks a bit bigger. Any forseen problems with this in my exsisting housing?
    As you can probably tell, I'm not an experienced rear end guy,(not with trucks anyway)
    I know...I could fork out the $$ and buy some fresh ones, but I'm cheap!!
    Any advice would be greatly appreciated.
    Thanks in advance, Doug
    Legend tbplus10 has a reputation beyond repute
    Mar 2007
    -97.0482020 N, 32.6625890 W
    1 Post(s)
    1 Thread(s)
    What do you use this truck for mostly? Off-roading or commuting.
    The 3.08 is a little bigger diameter wise, but this gear ratio was a factory available ratio for your truck.
    3.08's will leave your truck suffering off road, but on road the increase in mpg will make you happier.
    3.42's are actually a more popular gear for mid 80's Suburbans, but finding any size used gears is usually an iffy prospect. Most times gears are replaced because they developed problems and have to be replaced. Try looking on some of the off-road boards I know I've seen some for sale recently.
    Tim
    2011 Silverado 1500 LT
    2008 HHR LT
    1999 Tacoma SR5 TRD 4X4
    1993 Jeep Wrangler
    1991 Toyota Rock Crawler
    2009 Harley Davidson Nightrain
    2004 Harley Davidson FLHT "Bagger"
    2003 Glastron GXL Bowrider
    Jun 2008
    Thumbs up Thanks
    Thanks for the info, Tim..
    The truck is used for hiway , pulling a tin boat.and hauling supplies, a work truck mostly. It has a 4 speed auto tranni, with manual hubs. I'll check the off road posts. Cheers, Doug,
Similar Threads
  1. 1987 rear diff gear swap?
    By socal77k5 in forum Lifted & Offroad Suspension
    Last Post: 05-11-2010, 09:44 PM
  2. diff question
    By z3ro in forum Powertrain
    Last Post: 03-25-2010, 11:09 AM
  3. Rear Diff. question?? Help!
    By Tileman1 in forum Powertrain
    Last Post: 08-07-2009, 06:04 PM
  4. 95 2500 Burb Frt Pinion Gear Rebuild
    By Dj Friction in forum Powertrain
    Last Post: 02-01-2008, 11:03 AM
  5. diff question
    By homer911 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 12-20-2007, 10:12 AM
