Results 1 to 9 of 9
    Newbie tahoe101 is a glorious beacon of light
    Jun 2008
    Exclamation 1995 Tahoe rear end/differential compatibility...HELPP!
    Hey guys. Just registered here. I have a 1995 Tahoe and my differential just went down the drain yesterday with gear teeth missing and chunks all over. First question is, do you think its more cost effective to replace the differential gears or to replace the whole rear end? A friend of mine whom is a mechanic will be helping me here so im not brining it to a shop.
    Second, if I am going to replace the rear end, can I use a Chevy 1500 pickup rear end instead of a tahoe rear?? I have the 10 bolt with clutch type limited slip and 3.73 gear ratio. Would the pickup rear be the same ratio? Has anyone had any experience doing a rear swap?
    I only ask these questions because I am having a hard time finding a tahoe rear end at the junkyards. Anyone help would be great cause i need to get my hoe on the road soon. Thanks guys.
    Legend tbplus10 has a reputation beyond repute
    Mar 2007
    -97.0482020 N, 32.6625890 W
    1 Post(s)
    1 Thread(s)
    This question depends on your automotive skill level.
    If you can do some auto work swapping the whole rear axle would probably be easier.
    If you're an experienced mechanic with rear gear experience swapping the diff gears would be the cheapest route.
    Both methods would take about the same time.
    10 bolt gears/Diff are the same in the trucks, Tahoes, and Suburbans.
    Have you tried looking online at new replacements?
    Try randysringandpinion.com
    Tim
    2011 Silverado 1500 LT
    2008 HHR LT
    1999 Tacoma SR5 TRD 4X4
    1993 Jeep Wrangler
    1991 Toyota Rock Crawler
    2009 Harley Davidson Nightrain
    2004 Harley Davidson FLHT "Bagger"
    2003 Glastron GXL Bowrider
    Legend
    Pete95Sierra is a name known to all
    Jan 2008
    Morristown, NJ
    yea i agree with tim. if you know how to change gears its not to bad, and you can get new gears for relatively cheap. swapping in a new axle isnt too hard either if you know what your doing. and the 10 bolt axles are the same i believe in trucks and burbans and tahoes
    PETE
    95 GMC Sierra 2500
    3" Body Lift, 33" Goodyear MTR's
    5.7L 350 TBI Edelbrock SDT Exhaust, Flowtech Headers, K&N Intake
    Sold :(
    1999 Jeep Cherokee, 3" Rustys lift, 33" BFG MT's, locked, armored: Rolled :(
    2000 Jeep Grand Cherokee Limited. K&N Intake, Custom Kolak Exhaust
    Contact this GMTC Moderator for any problems or questions you may have
    Join the GMTC Facebook Group!!! Join Here
    Jun 2008
    Alright cool. Thanks for the replies guys. I figure Ill ask around at the junkyards for a 10 bolt rear with the 3.73 gears. It seems that it should be pretty common. You think I should ask for a specific rear for the tahoe or just any 10 bolt 8.5" inch rear with the 3.73 gears
  5. #5
    Legend
    Jan 2008
    Morristown, NJ
    just any should work
    PETE
    95 GMC Sierra 2500
    Sold :(
  6. #6
    Newbie koeito is a glorious beacon of light
    Oct 2008
    @ home
    Default 3 :73 gears
    Quote Originally Posted by Pete95Sierra View Post
    When I had my 95 rear end replaced, I was told that the end rear end HAD TO BE OUT OF A TAHOE or it would not fit. so make sure . I bought one in toronto for $1100 , after paying a guy $1900 to rebuild the old one and only drove less than 300 miles before wrecking the whole thing
  7. #7
    Jr. Mechanic moogvo is an unknown quantity at this point
    Mar 2006
    Cameron, NC
    Also make sure that if yours is a 4x4 that the gears in the rear are the same as the gears up front. You can't run a 4 wheel drive with different gear ratios front and rear.
    Look up the axle code. It is on a sticker, probably in the glovebox or in the door jamb. It is a 3 character code that starts with a G. this will tell you what your gear ratio is.
  8. #8
    Legend 95CTburb19 is a glorious beacon of light
    Apr 2007
    Umass / Newtown CT
    Quote Originally Posted by koeito View Post
    wow that is wayyy to much for a rear end. That sucks that you wrecked it.
    Dan
    1999 GMC Sierra 2500 350 vortec
    1967 Jeep M725 ambulance 230 tornado
    1990 Cherokee Limited- 3 inch lift on 33's
    ...and every one of em has issues
    If you have any questions or problems don't hesitate to send me or any other GMTC moderators a PM
  9. #9
    Oct 2008
    @ home
    Quote Originally Posted by tahoe101 View Post
    the rear end must be out of a 1995 Tahoe I found that out the hard way. There is difference in the length ,its only a little bit but must be correct
Similar Threads
  1. Rear differential
    By Adam47 in forum Lifted & Offroad Suspension
    Last Post: 12-13-2009, 02:09 PM
  2. Rear differential
    By silveradoguy87 in forum Powertrain
    Last Post: 02-10-2009, 01:43 PM
  3. Rear end/differential Compatibility
    By tahoe101 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 10-06-2008, 05:42 PM
  4. Rear end/differential Compatibility..HELP!
    By tahoe101 in forum Powertrain
    Last Post: 06-25-2008, 04:54 PM
  5. rear differential
    By brooklyn718 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 05-19-2008, 12:55 PM
