Results 1 to 3 of 3
    Newbie rod is a glorious beacon of light
    Mar 2008
    Default Fuel filter location
    2003 GMC Yukon. Where is the fuel filter located? Thanks for all the past help. I have no fuel pressure just don't want to beleive that its the fuel pump, but that may be what it is. I looked at the fuel tank because I was told you need to drop the drive shaft before droping the gas tank anyone know if this true. Thanks for all your help.
    Moderator
    GaryL is a glorious beacon of light
    Mar 2006
    The Colony, Tx
    It should be on the frame rail somewhere, just follow the lines from the tank forward and you should find it. I did find out that around 05, they stopped using external filters and only filter the pump itself inside the tank. Your 03 may be that way as well.
    You shouldn't have to remove the drive shaft to drop the tank. I dropped the tank in my dad's Yukon XL last week and the only thing I had to remove was the spare tire. That made it easier to get at the filler neck hose and the lines coming out of the back of the tank. There is also a vent line at the front of the tank that needs to be disconnected before you drop it or it will break when the tank comes down.
    Gary
    99 K 1500 Suburban
    78 Silverado Big 10 w/factory 454
    1977 Formula
    1976 Trans Am
    1980 Honda CB900 Custom
    Newbie mlvortec is a glorious beacon of light
    Jun 2008
    the fue filter is just inside the frame on the driver side nearly under the left rear door of the car.
Similar Threads
  1. Fuel Filter
    By waynebrv in forum Medium-duty Truck Forum
    Last Post: 02-06-2012, 03:21 PM
  2. help on fuel filter!!!
    By Silverado1500 in forum General Chevy Tech Q&A
    Last Post: 01-15-2010, 10:44 PM
  3. Fuel Pump Power Wire/Connection - Location?
    By alchemist1 in forum Powertrain
    Last Post: 10-07-2009, 10:20 AM
  4. Fuel Filter Location on "01 SIlverado 2500
    By loppy crimp in forum General Chevy Tech Q&A
    Last Post: 05-05-2009, 02:57 PM
  5. 2003 Yukon Flex Fuel - Fuel Filter
    By jnt412 in forum General Chevy Tech Q&A
    Last Post: 01-06-2009, 11:28 PM
