    Question Electrical problems
    I have a 2001 extended cab silverado and about 2 weeks ago the radio stopped turning off when I turn the truck off and open the door, and now the only way my power windows work is if both doors are open. I checked the wires going from the body to the door and they are fine. Any help would be great.
    Quote Originally Posted by Jim b View Post
    my guess is the RAP relay
    Do you know where the rap is located?
    should be in the fuse box.
    this relay is controlled by the BCM ...the coil return ground side is what the BCM grounds out to energize this relays control of the interior lights/radio/windows... so you have to see what is the cause of this .wiring, relay, bcm or something else. with diagram and a voltmeter it should not be too hard.
    Ok. I'll check it out. Thanks for the help.
