    Question 1995 Tahoe OBD 1, need help with programming
    Hi all:
    Can someone please help. I just got an original key fob but no instructions. Can someone tell me how to program it. Fob Model number is ABO0104T P/N: 15731442
    I have a 95 Tahoe with an OBD1.
    Thanks Much for any assistance.
    Aug 2005
    North Central Texas
    your lucky that your tahoe came with a remote-fob. my suggestion is go to the dealer and get them to do it. there the only people I know who can do that.
    Jr. Engineer Rumpamuro's Avatar
    Apr 2007
    Mississauga, Ontario (Canada)
    So your truck came stock with rke? if so :
    Ground the pin on the bottom left the DLC (pin G) then press a button on the first fob you want to program, then the locks will unlock and lock and i think the glass in the back opens too (just incase your wondering why its open after you finish) then press another button on the second transmitter you want to program (if there is a second one) and remember if theres one programmed, every time you ground this pin it gets erased, so you do them all at once. after you press a button on the second fob, they locks will lock/unlock and glass unlock again. once this is done, take off the ground, and it will do the whole unlock and lock thing again to tell you it was done properly, as long as you got the right transmitter, should work fine!
    --> Rocco "Rumpamuro"
    --> Apprentice Mechanic (Cars and Trucks)
    --> Mississauga, Ontario (Canada) eh!
    --> Vehicles on the driveway:
    -2008 GMC Acadia SLE AWD
    -2007 Silverado Classic Reg cab, long box.
    -2008 Pontiac Vibe (my dads fuel efficient way to go to work)
    -1996 Pontiac Sunfire GT
    Apr 2007
    The DLC (the thing you plug the scanner into to connect with the truck) its pins are labelled like this
    TOP
    F E D C B A
    G H J K L M "G" is the one you want to ground
    and also when you ground it at first it locks and unlocks i think as well to tell you it in program mode.
    Good Luck!
    Near Kankakee, Illinois
    Which pin - if there is one - is ground?
    Can you just do a loop in the 12 pin connector?
    Or do you have to go outside the connector for a ground?
    1994 Chevy 6.5 turbo diesel K3500 4x4 long bed, crew cab, 5 speed 235,000 miles
    1995 Chevy Tahoe 6.5 turbo diesel 4x4
    1995 Chevy 6.5 turbo diesel C2500 2 wheel drive, long bed, extended cab
    1996 Chevy K1500 Suburban 6.5 turbo diesel 4x4 245,000 miles
    1998 Chevy K2500 Suburban 6.5 turbo diesel 4x4 235,000 miles
    !991 International box truck, 4700 low pro, Spicer 6 speed, DTA 360, 18' box with side door. 500,000 miles, for sale $3000
  1. Transmission issue- 1995 Tahoe
    By blk95tahoe in forum GM Powertrain
    Last Post: 07-05-2010, 09:50 AM
  2. 1995 Tahoe LT $3500
    By Timmy6216 in forum Chevy Trucks For Sale eBay
    Last Post: 05-15-2010, 07:46 AM
  3. Posi in a 1995 Tahoe?
    By 1995ChevyHoe in forum GM Powertrain
    Last Post: 11-09-2009, 06:44 AM
  4. Can't Shift into gear!!! 1995 tahoe
    By Jstnwhlr27 in forum GM Powertrain
    Last Post: 05-05-2008, 11:09 AM
  5. 1995 Tahoe - bogging down - no power
    By BluezMom in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 02-02-2007, 07:26 PM
