    Default How do I fix the C0265 ABS Code?
    In my 2001 Suburban I have a C0265 code which is Electronic Brake Control Module Relay Circuit. What can I do to fix it? Both my ABS light and Park Brake light are on because of it. Since my suburban has the auto 4wd system it will not going into 4wd, so I need to get it fixed. Thanks
    Quote Originally Posted by cbe295 View Post
    The below Information should be able to help with DTC C0265
    G.M.Document ID# 1988903
    Subject: ABS Light On, DTCs
    C0265, C0201, U1041 Set and/or Loss of Communication with Brake Module (Reground EBCM Ground) #04-05-25-002D - (06/14/2007)
    2002-2006 Cadillac Escalade, Escalade EXT
    2003-2006 Cadillac Escalade ESV
    1999-2007 Chevrolet Silverado Classic
    2000-2006 Chevrolet Suburban, Tahoe
    2002-2006 Chevrolet Avalanche
    2002-2007 Chevrolet TrailBlazer, TrailBlazer EXT
    2003-2006 Chevolet SSR
    1999-2007 GMC Sierra Classic
    2000-2006 GMC Yukon, Yukon Denali, Yukon XL
    2002-2007 GMC Envoy, Envoy XL, Sierra Denali Classic
    2004-2005 GMC Envoy XUV
    Condition:...Some customers may comment that the ABS light is on. Upon further inspection, DTCs C0265 and C0201 may be set in the brake module. It is also possible for DTC U1041 to set in other modules. There may also be a loss of communication with the brake module.
    Cause....A Poor Connection at the EBCM ground is causing unnecessary replacements of Brake Modules.
    Important:....The EBCM Ground is different for each application. Refer to the list below for the proper ground reference:
    • Midsize Utilities = Ground 304
    • SSR = Ground 400
    Fullsize Trucks and Utilities = Ground 110
    Correction:....DO NOT REPLACE THE BRAKE MODULE.
    Perform the following steps to improve the connection of the EBCM Ground:
    ...Remove the EBCM Ground.
    ...The EBCM Ground is located on the frame beneath the driver's side door.
    ...If multiple grounds are found in this location, the EBCM ground can be identified as the heavy (12-gauge) wire.
    ...Clean the area, front and back, using a Whiz Wheel®.
    ...Install the ground, then the washer and then the bolt to the frame.
    Important:....It is important to use the bolts, washers and nuts specified in this bulletin. These parts have been identified due to their conductive finish.
    Install a washer and nut to the back side of the frame.
    Tighten
    Tighten the nut to 9 N·m (79 lb in).
    Cover the front and back side of the repair area using Rubberized Undercoating. An additional check can be made to ensure a good connection for the Battery Cable to Frame ground. It is possible for this ground to cause similar symptoms with the ABS as described above.
    Parts Information:....FULL-SIZE TRUCKS, SUVs AND H2
    Description.....Part Number#
    ***Bolt...........#11588564
    ***Washer.......#15650962
    ***Nut............#15672934
    ***Rubberized Undercoating/Paint-able...#12378398
  3. Likes Pikey, mfleetwood, dsfloyd liked this post
  4. #3
    Ok. I will have to try it when I have free time. Thanks.
  5. #4
    The EBCM relay circuit is internal to the module. You have to pull the module and open it to access the printed circuit board where the relays are soldered. The solder joints have cracked and need to be reflowed.
    Reflowing the solder joints fixed my ABS problem.
    I cleaned all the ground points under the truck and it did not help.
    You can try cleaning first the ground points as they are very easy to do.
    Here is what I did to fix the same problem in my 2001 Suburban.
    http://www.gmtruckclub.com/forum/sho...module-removal
    Here is the video.
    http://www.youtube.com/watch?feature=player_embedded&v=P_6Sk7-fm0I
    1993 964
    1996 318TI
  6. #5
    Nice. Video and all. Thanks.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk
    Steve
    10 Chevy Traverse LT AWD
