Where is the fuse panel on the new silverados. Its dark outside and I can't seem to locate it.
I also need to tap into an accessory wire for an amp so if anyone knows about that it would be great
Open the driver side door. Now look at the left side of the dash that faces away from you towards the door. The plastic piece covers the fuses..pull from bottom, it will pop out.
Bookmarks
