    Default Buzz/static on AM radio?
    What the heck causes the buzz/static when the stereo is on AM? Thanks.
    In short, electrical noise. Where the noise is coming from could be from numerous sources including power lines and the isolators on power poles, other bad electrical connections in houses and businesses, right down to plasma TVs with poorly designed power supplies. It can also potentially be caused by DC electrical interference from bad connections on the vehicle or spark plug wires that the insulation is failing on.
    Christopher
  3. Likes Pikey liked this post
  4. #3
    It definitely is something on the vehicle because it's there no matter where I go and it's constant. I've just put new plug wires on it so I can't imagine that being the problem.
  5. #4
    I put a HD Tuner in my truck and get most Am Stations in like FM sound...
  6. #5
    In many cases it comes thru the ignition system, alternator, leaky plug wires, (not the case here) faulty diode, and a host of other sources as mentioned, a quick 20 dollar fix can be found at the local radio shack or stereo shop, what you want is an RFI filter, with AM you can have radio frequency interference, the RFI filter will prevent that from coming thru your radio. Attaches to the radio power in, simple install. fluid filter, air filter, noise filter, man you need a filter for everything these days, lol.
    Life is short compared to history
    Rick (summitwhite11)
  7. #6
    Sr. Mechanic poncho62's Avatar
    Sep 2013
    Hanover, Ont, Canada
    Basically, AM is transmitted on a lower frequency than FM and is more susceptible to interference......
    More AM/FM facts
    AM FM
    Origin: AM method of audio transmission was first successfully carried out in the mid 1870s. FM radio was developed in the United states mainly by Edwin Armstrong in the 1930s.
    Modulating differences: In AM, a radio wave known as the "carrier" or "carrier wave" is modulated in amplitude by the signal that is to be transmitted. In FM, a radio wave known as the "carrier" or "carrier wave" is modulated in frequency by the signal that is to be transmitted.
    Importance: It is used in both analog and digital communication and telemetry. It is used in both analog and digital communication and telemetry.
    Pros and cons: AM has poorer sound quality compared to FM, but is cheaper and can be transmitted over long distances. It has a smaller bandwidth so it can have more stations available in any frequency range. FM is less prone to interference than AM. However, FM signals are impacted by physical barriers. FM has greater sound quality due to higher bandwidth.
    Stands for: AM stands for Amplitude Modulation FM stands for Frequency Modulation
    Range: AM radio ranges from 535 to 1705 kilohertz (OR) Up to 1200 Bits per second FM radio ranges in a higher spectrum from 88 to 108 megahertz. (OR) 1200 to 2400 bits per second
    Bandwidth Requirements: Twice the highest modulating frequency. In AM radio broadcasting, the modulating signal has bandwidth of 15kHz, and hence the bandwidth of an amplitude-modulated signal is 30kHz Twice the sum of the modulating signal frequency and the frequency deviation. If the frequency deviation is 75kHz and the modulating signal frequency is 15kHz, the bandwidth required is 180kHz
    Zero crossing in modulated signal: Equidistant not equidistant
    Complexity: transmitter and receiver are simple but in case of SSBSC AM carrier syncronization is needed tranmitter and reciver are more complex as variation of modulating signal has to converted and detected from corresponding variation in frequencies.(i.e. voltage to frequency and frequency to voltage conversion has to be done) which are quite complex
    Noise: AM is more susceptible to noise because noise affects amplitude, which is where information is "stored" in an AM signal. FM is less susceptible to noise because information in an FM signal is transmitted through varying the frequency, and not the amplitude.
  8. #7
    Standard headlights, or an upgrade?
    HIDs can cause the problem.
  9. #8
    Standard headlights. It's an alpine aftermarket stereo that has been working fine. The problem just came up the last few weeks.
  10. #9
    The lead from the antenna to the radio is shielded co-ax. For the shield to work, the base of the antenna needs to be grounded. Perhaps you've lost the antenna ground.
  11. #10
    Thanks RayVoy. I'll check that out.
