The following is an excerpt from a Wikipedia article on Suburbans.
The GMT800-based Suburbans were introduced in late 1999 as the 2000 model year. Chevrolet sold two models of Suburbans: 1/2 ton and 3/4 ton. They came in either LS or LT trim packages. All models came in either 2wd or optional push button 4wd(w/ low range transfer case). A tow hitch with a trailer brake controller was standard.
I'm considering buying an '02 to use for towing and I was wondering if they really do have a brake controller built in or whether the Wiki article should have just said that they were wired to accept a harness with electric brakes. I found an owner's manual but it did not say anything about a brake controller.
I think it's just that it's wired to be able to easily install one. It seems like the new Subs that come with factory trailer hitches have the 6 or 7-way RV plugs. (they look almost alike with the exception for the center reverse pin and I never took notice) Those that have that I think are set up so you wire up your brake controller to this proprietary GM pigtail and it just plugs into a certain spot on a junction block or something under the dash. Mind you, this is all recalling what I've read in other threads here and may or may not be accurate. Good luck!
Christopher
1991 Chevy Suburban 1/2 ton 2WD w/ chevy SBC 350-3/4 ton drivetrain upgrade w/4.10 gears 194K miles
2005 Saturn ION-2 Stock 200K miles (In 6 years...ouch)
1982 Bronco, 1993 Bronco, 1971 M35A2 Deuce and a Half
When I got my 2000 Silverado there was a wiring harness in the dash for hooking up a brake controller. The instructions as to where to plug it into the harness was also there. From there hooking it up to any controller was simple.
2000 4x4 Ext. cab 5.3 Z71
2009 Corolla
Bookmarks
