Results 1 to 5 of 5
Thread: 2 problems
    Sr. Apprentice Opex is a glorious beacon of light
    Jul 2008
    Default 2 problems
    when i bought my truck the cab had been switched out cuz it was in a wreck. now the buys that did it must have screwed something up cuz theres to problems there nothin big but there annoying...
    frist off is the ignition box... i cant turn the key back into the battery save or wutever its called... the key only goes back form enough to turn the truck off... when i turn the truck off the key dont go back far enough to turn the interior lights off they stay on till the turns them off with the power save thing... and i cant turn the key back like i said so my question is... does anyone know how i can fix this or am i gunna have to take it to a shop?.
    and the second problem is the slider for the temp on the drivers side... i think theres a short cuz the passenger side temp slider works but this year when i went to turn the AC on it worked fine the the passenger side my my side is still blowin hotair... anyone had this problem?
    2006 2500HD Silverado 6.0L
    Jr. Engineer GoFastPadre is a splendid one to behold
    Apr 2008
    Lebanon TN
    I think that the problem is in the ignition switch its self. I would replace that first and if that does not work I would take it to the shop. I just wonder if they put in a new/different steering column in it when they did the swap. Hope this helps. Chris
    Chris S. The GoFastPadre I like to drive fast and I've got the speeding tickets to prove it. 00 Sierra Z71 ECSB K&N CAI Pacesetter Shorties (soon to be replaced with LT's) Magnaflow HFC's Flowmasters with True Duals and H-Pipe more mods to come
    Master Mechanic collinsperformance has a reputation beyond repute
    Dec 2006
    Sacramento, California
    sounds like time to get a shop book and follow the wires. i bet some have been swapped......mike
    Michael Collins
    1993 4X4 Suburban
    many other toys as well
    Jul 2008
    hey shouldnt have swaped anythng cuz the only damage to the original cab was right above the drivers door... like they drove into something that didnt have enough clearence
  5. #5
    Dec 2006
    you do not know what they swapped they could have swapped the shell or the shell and parts if they were already installed....mike
    Michael Collins
    1993 4X4 Suburban
Similar Threads
  1. S10 ZR2 4x4 problems
    By footballmn in forum Powertrain
    Last Post: 01-21-2010, 09:35 AM
  2. 4wd problems
    By NewfZ71 in forum Powertrain
    Last Post: 01-11-2010, 11:35 AM
  3. 4wd problems.
    By 95Chevyk1500 in forum Powertrain
    Last Post: 12-10-2009, 02:05 PM
  4. Chevy Silverado Heater problems blower problems
    By bidutch in forum Powertrain
    Last Post: 12-13-2007, 06:59 PM
  5. Got a few problems
    By 95chevyguy in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-16-2007, 01:03 PM
