Results 1 to 10 of 19
    Default v6 problem ~ Won't Start in Damp Weather - 1999 Chevy Silverado 4WD
    1999 Silverado v6 4x4 will not start in damp rainy weather. any ideals how to fix the problem, thanks
    Have you checked your air filter? Maybe your filter is clogged/wet and is suffocating the motor? Will the motor turn over if you turn the key?
    I had already disconnected the air filter, no luck with that. engine turns over good.
    Have you checked your fuel pressure? It sounds like a fuel issue. That or one of the sensors on the intake side may not be reading right in damp conditions.
    Maybe you have some ignition wire problems, give those a check out.
    Mods:
    Advent OGM1 Navigation
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    Flowsound 40 Muffler
    Chrome Tailgate Handle Cover
    TonnoPro HF-155 Tonneau Cover
    remove the distributor cap check the rotor / cap for water. wires on the v6 need to be routed as OEM built or you get these type problems.
    x2 on checking the cap and rotor. I had a truck in a week or so ago that had the same issue. He had taken it to multiple shops and a dealer. No one could figure it out. I talked him into letting me throw a cap, rotor, and wires on it. Problem solved. You can always pop the hood in a dark garage and spray the wires down with water. Look for arcing.
  8. Likes the phantom liked this post
  9. #8
    being the v6 engine this is the one where the ac lines drip condensation on the rotor cap ?
    if so these lines need be wrapped with tubing insulation to prevent this driping on distributor.
  10. #9
    Does it crank? I had that issue about 5 years ago and it ended up being my started. There was this little rubber piece on the bottom that was gone. It allowed moisture in the starter making it not crank. May be something to look into.
    -K&N Air Filter
  11. #10
    I don't believe the NBS has a distributor cap. I thought GM went to distributorless ignition on the Silverado starting in 1999.
    Mods:
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
