    Default pros and cons of leaf spring helpers
    Please I need to get some insite on the best and worst spring helpers. I am looking at the bolt on type for my 1991 V1500 1/2 ton. It has been suggested that my original springs are sagging and I can not afford a new set right now.
    are you referring to air bags or add-a-leafs, or something else? An add-a-leaf would probably be your easiest and cheapest method to reduce the sagging. Essentially what you are doing is dissasembling the leaf pack and adding another leaf in. Hope this helps
    Christopher
    No, no air bags.....Just bolt on helpers/add-a-leaf.....I am hoping that I can use one that will not require me to un-bolt the rear axle from the leaf. I found one from Superior that bolts to the bottom back half of the leaf. The problem I am finding is that this paticular one is rated for a light truck. I do not see my 1/2 ton 4X4 as a light truck.
    Only real negative with add a leaf is that unloaded ride quality will normally suffer. Harsher ride, maybe some rear axle hop on uneven surfaces, etc.
    Check out activesuspension.com. I had 'em on my old Tahoe. No negative side effects, improved handling, and even easier to install.
    2009 GMC Sierra Denali AWD
    Fabtech has a decent AAL. Usually 4Wheelparts wholesale has the best price for Fabtech parts.
    i would say look for an add-a-leaf too. and our trucks are considered "light" trucks
    PETE
    95 GMC Sierra 2500
    3" Body Lift, 33" Goodyear MTR's
    5.7L 350 TBI Edelbrock SDT Exhaust, Flowtech Headers, K&N Intake
    Sold :(
    1999 Jeep Cherokee, 3" Rustys lift, 33" BFG MT's, locked, armored: Rolled :(
    2000 Jeep Grand Cherokee Limited. K&N Intake, Custom Kolak Exhaust
    Contact this GMTC Moderator for any problems or questions you may have :great:
    Join the GMTC Facebook Group!!! Join Here
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    I put an Add-a-leaf on my 87 Blazer because of saggy springs. Inexpensive fix for sure!
    Darcy
    Washington State
  1. Edelbrock Carbs - Pros & Cons
    By 85 Silverado in forum Chevy C/K Truck Forum
    Last Post: 07-23-2010, 02:34 AM
  2. looking to buy 1500/2500 Pros/Cons
    By bhsballer76 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 02-25-2010, 10:01 PM
  3. is there any pros and cons to....
    By kukini808 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 12-29-2009, 05:39 PM
  4. Undercoating Pros and Cons
    By Ratchet Thunderbolt in forum Chevy Truck Accessories
    Last Post: 11-30-2009, 04:06 PM
  5. E-85 Pros and Cons
    By s5belford in forum General Chevy & GM Tech Questions
    Last Post: 08-24-2009, 01:11 AM
