Results 1 to 5 of 5
    Jr. Apprentice toothnet is a glorious beacon of light
    Mar 2008
    Utah
    Default Am I an LLY or LBY?
    Can someone tell me where to look to find whether my 2004 duramax is LLY or LBY? I used to keep the original sticker from the window in my glove compartment but it doesn't seem to be there now. I also thumbed through the owners manual. Is there someplace on the body of the truck I can look?
    Thanks.
    2004 Duramax, 4" Tuff Country EZ-Ride Suspension Lift,
    Toyo Open Country MT tires
    2007 Cadillac Escalade, 20" Proxes S/T tires (Wifes)
    2008 Cobalt 222 Boat
    Legend retired2001 is a glorious beacon of light
    Nov 2006
    Canyon Lake, Texas
    I''m not sure on yoiurs, but look and see if there is a list of numbers on the glove box door. It is usually printed there. Good luck!
    2010 Z/71 Colorado C/C
    Black 4X4 w/5.3L V8
    2007 Winnebago Adventurer
    w/8.1L Chevy & Allison 6spd.
    Canyon Lake, Texas
    Moderator
    dwill3015 has a reputation beyond repute
    Jan 2007
    Yacolt, Washington
    There are 4 generations of Duramax's to date. LB7, LLY, LBZ, LMM. The LLY came out in 2004 so I'm pretty sure that's what you have but usually the 8th didgit in your VIN code will determine which duramax you have. Here is a LINK that will give you more details on the different versions.
    Darcy
    Washington State
    Sr. Apprentice BigRedChevy is a glorious beacon of light
    Jun 2008
    Greenville, KY
    Look at the 8th digit of your vin #
    8th Vin #1-LB7 300 hp
    8th Vin #2-04.5-05 LLY 310hp autos only, 300 hp manual trans and 4500/5500
    8th Vin #3-06 LLY ratings are the same as vin 2
    8th vin #D-LBZ 360 hp auto only, not an option in manual trans or 4500/5500 trucks>
    8th Vin #6-LMM 365 hp
    05 Chevy LLY Crew Cab LT Dually 4x4, Crank it up Diesel Tie rod sleeves and centerlink, BD Diesel Remote Fuel Filter, EGR Blocked, PPE Hot+2 ET Xcellerator, TTS Dual Lift Pumps, FPRV Shim, Bullydog Outlook Monitor, AFE Stage 2 CAI, BD Diesel Manifold, Diamond Eye Turbo Direct Pipe, Diamond Eye 5" exhaust, Level Kit, Suncoast Stage IV w/ 1056 and Allison Deep pan TC
    1981 VW Rabbit Pickup, 1.6L Diesel, 4 Speed Manual, 35 MPGs
  5. #5
    Mar 2008
    Utah
    Thanks a lot. Much appreciated!!!
