    Nov 2008
    Albuquerque, NM
    Default maintenance required? -- 2008 Silverado, only 41K miles
    Due to deployments and TDYs, my 2008 Silverado has only 41K miles. Aside from oil changes and having the transmission fluid changed when my leaking rear main seal was replaced, I haven't hit any of the mileage thresholds for scheduled maintenance yet. So weighing the age against the mileage, any opinions on what scheduled maintenance should I bump up and accomplish now? Especially concerning fluids, I'm not having any issues but do transfer case/brake/power steering/radiator fluid, etc. have a life span, regardless of mileage? Thanks.
    Ruby Red Metallic 2008 Silverado Z71 Ext Cab -- Rancho 4" Lift, 20x10 Chrome XD Rockstars, 305/55/20 BFG Mud Terrains
    I would do a coolant flush. That stuff has a life of around 5 years and is known to corrode the crap out of things. I would also change the fluid in your diffs and T-case. I think that t-case is recommended at 50,000 anyway. As far as brake fluid and ps fluid. You will not hurt anything changing them. I would consider it.
    Pretty much what @Pikey said. They have been in for a few years so doesnt hurt to change them.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
