Results 1 to 3 of 3
    Newbie mvpadron is a glorious beacon of light
    Jul 2008
    Default Noise from the R front
    I have a 04 Siverado, and over the past couple of days I've been getting a high pitch noise coming from the right front of the wheel and it's getting worse every time. It gets louder when I turn the wheels either to the left of the right. I checked the brakes thinking that the pads may be worn but there was alot of pad left. But I did notice that when I had pulled on the wheel there was a little bit of play. Coud it possibly be my hub bearing going bad? If so is it an easy job to fix on my own?
    Master Mechanic omegafiler is a glorious beacon of light
    Apr 2005
    TX
    Definately sounds like a bad wheel bearing. If there is side to side play in the wheel when you have it lifted, the bearing just needs to be replaced.
    As for the difficulty, just depends on your experience and what tools you have. If you haven't done it before, I'd suggest picking up a Helms manual or something similar. See what's involved, then decide if you want to do it yourself. For some its easy, and for other's, it's easier to have somebody else do it.
    2009 GMC Sierra Denali AWD
    Jul 2008
    it was the wheel bearing and it wasn't that bad to take off. thanks for the advice
Similar Threads
  1. Noise in front end
    By mvoss2576 in forum Powertrain
    Last Post: 02-08-2010, 08:32 PM
  2. Noise up front
    By R6Hauler in forum Powertrain
    Last Post: 11-30-2009, 04:51 PM
  3. noise in front end
    By bigproskine in forum Lifted & Offroad Suspension
    Last Post: 10-05-2009, 06:48 PM
  4. noise in front end
    By smoke20 in forum General Chevy Tech Q&A
    Last Post: 09-08-2008, 01:47 PM
  5. noise from front end
    By frogate in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 12-31-2006, 07:26 PM
