Results 1 to 9 of 9
    Newbie canes fan is a glorious beacon of light
    Jul 2008
    Default 2003 silverado heated seats
    HELP I have a 2003 silverado and the heated seat on the drivers side comes on all by itself. I turn it off and it comes back on. Sometimes it just goes on and off all by itself. I looked at the switch in the door and the wires are soldered into the switch. Is there a relay or something I can Change ??
    Jul 2008
    Anyone ? Anyone? Dont post all at once !!!
    Moderator
    dwill3015 has a reputation beyond repute
    Jan 2007
    Yacolt, Washington
    I had probs once with my heaters not working at all and then would not stay on longer than 15 seconds. The dealer replaced some melted wires and elements and now works great so i would recommend taking it to the dealer.
    Darcy
    Washington State
    Administrator Steve has much to be proud of
    Dec 2004
    Arlington, Texas, United States
    10 Post(s)
    1 Thread(s)
    It comes on when going down the road? I've seen/read about problems with these, but typically the #1 problem is that the wires/leads get worn down with use/sitting and they stop working, not come on by themselves. I agree, I'd look under the seat itself first.
    Steve
    02 Chevy Trailblazer LS (110K+ miles - loaded except for 4WD - WRECKED!)
    99 Chevy Cavalier LS (105K+ miles - commuter car)
    78 Chevy Suburban Silverado (454, 3/4 ton)
    62 GMC 3/4 ton Pickup (350 police interceptor)
    Search Before Posting | Fill out Your Profile & Signature
    My Trip to GM Detroit | Meeting w/ GMC, Buick & Cadillac
    Replacement Chevrolet Tires
  5. #5
    Jul 2008
    UPDATE : Well the Drivers side seated hasn't acted up in almost a week. I dont Know. Thanks for your suggestions. I will keep you updated if it happens again.
  6. #6
    Sr. Apprentice smainsw is a glorious beacon of light
    Dec 2007
    Ontario, Canada
    Default 05 heated seats
    I'm having the same problem with my 05 silverado, it only happens once and a while though, the other morning I went out to my truck and the battery was dead, I almost suspect the heated seat turned on by itself in the middle of the night and killed the battery, there wasn't even enough power for the guages to come up.
  7. #7
    Legend Springthing has a reputation beyond repute
    Aug 2008
    East of Branson, Missouri
    1 Thread(s)
    The heated seats should not be able to come on with the ignition in the off position.
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
  8. #8
    Sr. Apprentice SlickMachine is a glorious beacon of light
    Nov 2008
    Stow, OH
    Quote Originally Posted by smainsw View Post
    Doubt it, Motor has to be running for the seats to come on.
    2005 Sierra 1500 Z71 Crew Cab
    Pro Comp 6" Lift
    4.56 Gears
    35" Toyo M/T's on 20" Eagle Alloys
    K&N Intake
    Flowmaster Exhaust
    SuperChips Programmer (worthless)
  9. #9
    Dec 2007
    Ontario, Canada
    I thought the engine would have to be running in order for the seats to come on but something definately killed my battery, I was figuring that would have the kind of draw required to. Had a dead battery a couple of times last winter, ended up turning off the courtesy lights and anything that I could that would be on for any time when I turned off the truck and replaced the battery, and all has been good as far as the battery dying, but I am having problems with the heated seats, had some last winter too, kind of figured thats what could have killed my battery but still would like to get the seat fixed.
Similar Threads
  1. Heated Seats in 99 Suburban
    By Karey in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 08-30-2011, 11:29 PM
  2. Heated seats
    By chas in forum General Chevy Tech Q&A
    Last Post: 11-08-2010, 10:21 AM
  3. Replies: 0
    Last Post: 08-13-2009, 04:50 AM
  4. 2006 Silverado Heated Seats
    By redsflhtci in forum General Chevy Tech Q&A
    Last Post: 12-08-2008, 10:54 AM
  5. heated seats
    By ju0202 in forum Chevy C/K Truck Forum
    Last Post: 01-25-2007, 04:11 PM
