Results 1 to 9 of 9
    Sr. Apprentice neversummer is a glorious beacon of light
    Jul 2008
    Santa Clarita CA/ LA / So Cal
    Default Mysterious Loss of Fuel Pressure overnight
    Hello guys, and Girl.
    I've seen this topic come up before somewhere, but maybe you guys have a suggestion since the dealer has their head up their You know what.. and just wants to check random things.
    Hard crank over in the morning or after my truck sits a while..
    6.0L 2004 Silverado. but if i let it sit on (on) position before cranking over a bit starts right up.
    Hear the fuel pump whining when i turn on, and i dont have this problem once i dirve it , only if it sits for a couple hours .. and specially over night.
    Starts right up if i pause on the on position for a few seconds before cranking over the starter
    but if i jump in and try to start up it doesnt want to.. (pain for remote start)
    Im presuming its fuel pressure regulator possibly and or somwhere on the fuel rail its losing pressure over night, is it possible a injector is leaking, where and how can i check fuel pressure at the fuel rail, can i use a tire pressure gauge?
    I have already replaced the Fuel filter with a brand new Fram about a week ago.
    what is optimum pressure for the fuel rail?
    Jason * So Cal
    2004 Silverado 2500HD 4x4 Crew cab LT2
    2004 Yamaha YZ450f Dirt Bike
    Moderator
    GaryL is a glorious beacon of light
    Mar 2006
    The Colony, Tx
    You need a minimum of 60 psi to start. It takes a fuel pressure tester to test, do not use a tire pressure gauge. One of your local auto parts stores may loan you one
    It sounds like the pump may be going out. Mine just went through the same symptoms and finally quit starting all together unless I used ether. Replaced the pump and all is well now.
    Gary
    99 K 1500 Suburban
    78 Silverado Big 10 w/factory 454
    1977 Formula
    1976 Trans Am
    1980 Honda CB900 Custom
    Jul 2008
    hummmm...
    interesting, cause I have no problems with fuel pressure once its started, and or once i have started it once, it will start right up again if stopped. its only if my truck sits over night or a prolonged amount of time. I will check the fuel pressure at the rail after running it and first thing in the morning before I start it....
    Am i correct in presuming that there should be fuel pressure at the rail ALL the time.
    Jason * So Cal
    Moderator
    Mar 2006
    The Colony, Tx
    There should be some pressure there, but not the full 60 psi like when the pump is running.
    Just before mine died, if I was able to start it once, I could restart it multiple times. It was hardest to start in the morning, but ok the rest of the day.
    Gary
    99 K 1500 Suburban
    1977 Formula
    1976 Trans Am
  5. #5
    Jul 2008
    Quote Originally Posted by GaryL View Post
    wow $158 bucks for a fuel pump, i think it works fine, I am gonna try the regulator which is only $20 first. and check for leaks around the fuel rail and make sure the pressure is up to par..
    thanks
    Jason * So Cal
  6. #6
    Moderator
    Mar 2006
    The Colony, Tx
    Where did you find a fuel pump for $158? I just paid $220 for mine through Oreilly Auto Parts, and that was after a $56 discount.
    Is the regulator external on yours or is it under the intake like the old 5.7 Vortecs like mine?
    Gary
    99 K 1500 Suburban
    1977 Formula
    1976 Trans Am
  7. #7
    Sr. Mechanic FireRed is a glorious beacon of light
    Oct 2007
    You should always wait the 10 or so seconds for the pump to stop indicating the system is pressurized, being a mechanic I have done so for many years. Recently at 141,000 miles my sub starter started to act up, I pulled and tore it down to find it in near new condition inside needing only a solenoid. My last FI truck had 171,000 and never had a starter, yet you go to any electric repair shop and most people are eating starters. They have to have instant start RLOL!!!!!!!!!!!!!!!!!!!!!
    Happy 2 Wheeler!
  8. #8
    Master Mechanic collinsperformance has a reputation beyond repute
    Dec 2006
    Sacramento, California
    i feel good since i upgraded to a Bosh hi-pro pump for $65 at napa.
    ok- your issue there is a check valve on the FMU and it is starting to go bad.....mike
    Michael Collins
    1993 4X4 Suburban
    many other toys as well
  9. #9
    Jul 2008
    Right here. a lot cheaper than the Delphi or Bosch but im sure works just as well
    http://www.rockauto.com/catalog/rafr...1427565k872337
    Jason * So Cal
Similar Threads
  1. 5.3 fuel pressure?
    By slider_buck in forum Performance & Fuel
    Last Post: 04-08-2010, 06:25 PM
  2. 89 Burb...sudden loss of fuel pump and loss of check engine light
    By Big6ft6 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-05-2010, 08:21 PM
  3. 5.3 fuel pressure
    By shayes41 in forum Performance & Fuel
    Last Post: 02-25-2010, 10:01 AM
  4. Understanding Fuel Injection & MPG Loss
    By brtt485 in forum Performance & Fuel
    Last Post: 12-29-2009, 07:20 PM
  5. No fuel with no oil pressure
    By 70boss302 in forum General Chevy Tech Q&A
    Last Post: 08-23-2008, 12:28 AM
