My second generation 1999 Silverado 1500 4wd 5.3L is having some rear end trouble. I first thought it was because my tires were practically bald. I just bought some brand new BFG's A/T yesterday and experienced the same problem. When I make turns at slow to moderate speed it feels like the rear end locks up. Almost like the Anti lock brake system kicks in. The wheels start to churp and stutter and some times makes a loud noise. This also sometimes happens when I first take off from a dead stop. I checked the fluid and it seemed to be full. Im going to pump some more in there for sure, but im worried its a major problem.
Thanks
before putting any fluid in i pull the cover and look the gear and diff over. you can get a new gasket and oil for not too much. it sounds like you got a bad spider gear or something binding the diff up. the only way to be sure is to open her up and look closer...........mike
Michael Collins
1993 4X4 Suburban
many other toys as well
Do you have an open diff or a G80 "Gov-lock"? If you have a G80, it is possible that it is stuck engaged.
'98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
'92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
"My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
i would say open her up and check the spider gears over. look around in there, something is not right. something may be wrong with your ring and pinion binding as well
PETE
95 GMC Sierra 2500
3" Body Lift, 33" Goodyear MTR's
5.7L 350 TBI Edelbrock SDT Exhaust, Flowtech Headers, K&N Intake
Sold :(
1999 Jeep Cherokee, 3" Rustys lift, 33" BFG MT's, locked, armored: Rolled :(
2000 Jeep Grand Cherokee Limited. K&N Intake, Custom Kolak Exhaust
Contact this GMTC Moderator for any problems or questions you may have
Join the GMTC Facebook Group!!! Join Here
It'd be one of the RPO codes listed on the RPO sticker in the glovebox. It's a sticker with a bunch of 3 character codes like G80. Just look through the list for G80 to get your answer...
Christopher
1991 Chevy Suburban 1/2 ton 2WD w/ chevy SBC 350-3/4 ton drivetrain upgrade w/4.10 gears 194K miles
2005 Saturn ION-2 Stock 200K miles (In 6 years...ouch)
1982 Bronco, 1993 Bronco, 1971 M35A2 Deuce and a Half
Maybe some of the more expert guys here can tell you if this diff has some limited slip capability? I think they require some special additive ??If it is limited slip , it might be worth a shot.
Luck,
Charlie
1998 suburban-
1/2 ton
199500 miles
River
Ridge,LA
you need to know if you have one before you get the oil. only way to know for sure is open the cover and look. if the cover never been off then look at the glovebox id tag other wise anyone could have changed the diff or even rear end....mike
Michael Collins
1993 4X4 Suburban
I looked over my part identification tag in the glove box and i found G80. Is it possible that the gov-lock is stuck engaged. If so how to I disengage it? I dont want to tear her open because I have no idea what is going on in there. I would like to eliminate all the possible easy fixes before I haul her off to a mechanic.
thanks again guys for all your help, this website is a god send!
sorry to say but if it id the gov lock then you will have to open her up and look at what has failed. i do not have any time on a gov lock system so i can not say what to look for but i bet it will stand out.....broken center bolt or spider gear or clutch disc.........mike
Michael Collins
1993 4X4 Suburban
Bookmarks
