need help trying to find the tac wire at the computer witch plug witch wire
97 sub 2wd gas
thanks josh
google for wiring diagrams that inclue the tach wire...there should be a wire near the distributor in the engine bay that has the tach pulses...at least on the older trucks...
Christopher
1991 Chevy Suburban 1/2 ton 2WD w/ chevy SBC 350-3/4 ton drivetrain upgrade w/4.10 gears 194K miles
2005 Saturn ION-2 Stock 200K miles (In 6 years...ouch)
1982 Bronco, 1993 Bronco, 1971 M35A2 Deuce and a Half
i have 1 from bulldog has ben great on the last 2 i did it just tells me the white wire at the computer .
i have 5 plugs and 3 white wires just do not want to mess anything up
Im gonna assume its a c1500 sub, i donno which wire it is on the ecm, but if you go to the instrument panel connector its pin 6 (white wire)
If you look at the connector sideways theres a space between two rows of pins, now one side has seven pins on each row and the the other has 9 now you want to go on the side with the 7 pins (14 total) and from the middle(space) skip the first pin and the second is pin 6 i hope pin 22 (the pin right beside it next row) isnt white as well. Good Luck.
--> Rocco "Rumpamuro"
--> Apprentice Mechanic (Cars and Trucks)
--> Mississauga, Ontario (Canada) eh!
--> Vehicles on the driveway:
-2008 GMC Acadia SLE AWD
-2007 Silverado Classic Reg cab, long box.
-2008 Pontiac Vibe (my dads fuel efficient way to go to work)
-1996 Pontiac Sunfire GT
thanks for the help will ck it out
Bookmarks
