    Sr. Apprentice GeorgiaZ71's Avatar
    Nov 2013
    Loganville, GA
    Default New tires - is a speedo adjustment necessary?
    Hi All,
    I tried using the search function, and I didn't find anything. So sorry if this has been asked a thousand times!
    So within a 2 weeks of getting my 2014 (150 miles on her), I had the level kit and bigger Wrangler Duratracs put on.
    My question is, going from a 265/60/18 to a 275/70/18 - is my speedometer / odometer off you think? I guess I could download some GPS app on my phone and test it...but thought I would ask here first.
    If it is - what's the recommended point for getting the old tune and reflashing the ECM? If the speedo is off by just a little - would you still recommend? (Obviously if it's like 7+mph off, I think I would... but what if it's only 2-3mph off?)
    Thanks!
    2014 Chevrolet Silverado Z71 4x4 | 2.5" level/lift | 275/70/18 Goodyear Wrangler Duratrac
  2. Likes Steve liked this post
  3. #2
    Quote Originally Posted by GeorgiaZ71 View Post
    Hi All,
    Thanks!
    There are a couple of reasons you would want to have the Trucks Computer Re-Programmed to Correct your Speedometer Readings,
    which will Be Off with this change in Tire Size(As Shown Below).....as the Vehicle’s Computer Calculates your Speed based on the Diameter of the Stock Tires, and with this Change in Tire Size, the Vehicles Computer doesn’t know how Fast your Vehicle is going......also with this change in Tire Size, your Transmission may Not Shift Correctly......
    Most Hand-held Programmers have the feature of Correcting the Speedometer Readings, when there's a Change in Tire Size and/or Change in Gear Ratio.
    Here are the Specs for Both Tire Sizes you've mentioned
    Typical Weight ~ 26 lbs / 12 kg ~ 18 lbs / 8 kg
    Tires: Tire 1 Tire 2
    Tire size 265/60-18 275/70-18
    Section width 265 mm (10.4'') 275 mm (10.8'')
    Sidewall 159 mm (6.3'') 193 mm (7.6'')
    Tire Diameter
    775 mm (30.5'') 843 mm (33.2'')
    68 mm (8.8%) taller.
    Rim sizes 18x7.5 to 18x10 18x7.5 to 18x10.5
    Circumference 2434 mm (95.8'') 2647 mm (104.2'')
    Revs per mile 661.3 608
    Speedometer Assuming that this is OEM tire and speedometer readings are correct >>> Speedometer reads 60mph actual speed will be 65.3mph 8.8% faster.
    Edit:....IMO....you should have the Speedometer Corrected, for this Change in Tire Size.
    Last edited by 99'HEARTBEAT; 11-21-2013 at 05:33 PM. Reason: Added some more Infor.
  4. Thanks Steve thanked for this post
  5. #3
    GPS tells you how fast, you are going! If not, GPS model? Yes.. Get a "SCT" programmer, http://www.sctflash.com/index.php I am not a rep, just a Owner of their product.
    2010 GMC SIERRA CREW CAB (Silver) 4x4, ReadyLift 2.5" Level Kit, 305/60/18 Dick Cepek Mud Country, Go Rhino Nerf Bars, Husky Liners front and rear, Bushwacker Bed Rail Caps, SCT Programmer.
  6. #4
    Sounds like an excuse for a custom tune with a diablo tuner from @06MonteSS to me!! There are a bunch of satisfied customers of his here.
  7. Likes 99'HEARTBEAT liked this post
  8. #5
    I second the tune from Lew. My truck is a beast since he's been working on it. And we're not yet done! For the price you can't beat it!
    2011 Chevrolet Silverado 5.3L LT
    Line-X bed--Line-X Aries Step Bars--Blacked out bow ties--Flowmaster exhaust--Black low-profile UWS toolbox--Weathertec floor mats--5% tint all around--2" leveling kit--Removed front air dam--K&N 77 Series CAI--Diablo Trinity--Diablew custom tune...
  9. #6
    Nov 2013
    Loganville, GA
    Quote Originally Posted by JimmyA View Post
    Well, I just use my Chevy MyLink system for Navigation now... and sometimes my phone. But now that you mention it, my old TomTom GPS did give me a speed readout. But the current system doesn't display my actual speed. I will check into both an SCT or Diablo Tuner. I was thinking about exhaust and CAI...I might as well order it all with the tuner. Shopping time! Thanks everyone!
  10. #7
    There are some iPhone / Android apps that will give you your speed and other driving information as well, they can be very useful in helping to determine how much off you are.
    Steve
    10 Chevy Traverse LT AWD
