Ok, I know "there aren't any stupid questions" but this sure feels like one! When you get on the gas (WOT), is oil pressure supposed to raise? I just did a Seafoam treatment with one can in the gas tank, 1/2 in the oil, and 1/2 in the booster line. I have never really paid attention to it before, but since I "changed" something, I was paying extra attention to details. If it's not normal, could it be that there is too much fluid in the oil pan after I added the Seafoam, causing higher pressure? If this is normal, please let me know...and try not to laugh at me too much![]()
Matt
Hallsville, TX
2005 Silverado 1500 LS Crew Cab 5.3L 2WD
K&N FIPK II
Magnaflow Exhaust
Hypertech Max Energy Programmer
Suspension Leveling Kit
Putco Element Window Visors
Carriage Works Billet Grille
TruXedo TruXport Tonneau Cover
1st question after running the seafoan in the oil you have changed the oil and filter?
2nd is the pressure in the 20-60 PSI range? if so no issues
i had a couple cars that the pressure went up after cleaning as long as it is in range no issues.
there might be some junk in the line blocking the flow some and the presure will rise until it passes the system and into the filter. i think you are fine but what is the pressure?
Mike
Michael Collins
1993 4X4 Suburban
many other toys as well
Well, I just put the Seafoam in this afternoon. I plan on changing the oil, oil filter, and fuel filter next week.
I just went out there and rev'd the engine and the pressure would go up to about 70. It only happens if I really get on it. It runs at normal pressure (about 50-55) when idle. You think I'll be alright? If it's a problem, would changing the oil fix it?
Matt
Hallsville, TX
K&N FIPK II
Magnaflow Exhaust
I wouldn't wait til next week to change the oil. I don't think it's supposed to stay in more than just a short time (though I could be wrong). The oil pressure at idle will be lower than it is at WFO, so that's not an issue.
Gary
99 K 1500 Suburban
78 Silverado Big 10 w/factory 454
1977 Formula
1976 Trans Am
1980 Honda CB900 Custom
if i recall the directions say you can leave it in for 100-200 miles i have to re-read the can. 70 psi is not bad at idle mine drops to 20-25 and as i gain in the pedal my pressure goes up. ....mike
Michael Collins
1993 4X4 Suburban
Bookmarks
