Results 1 to 10 of 14
    Jr. Mechanic Bowtied's Avatar
    May 2009
    2004 Silverado 5.3L
    Default Will a 265mm Tire it on stock rim?
    Hi guys my stock wheel has the 255/70/16 tire on it, would a 265/70/16 tire fit?
    Master Mechanic clgoch187's Avatar
    Aug 2010
    Gettysburg, Pennsylvania, United States
    Yup. I'm guessing someone put smaller tires on it. 265s are the oe recommended size but a lot people go to the 285/75 that should be the biggest you can go with out rubbing( at least without any lift) on a 4wd. If yours is 2wd you probably don't wanna go any bigger than the 265 without doing a little research first.
    These should be a sticker inside your driver side door jam with the recommended size a tire pressure
    03 Silverado 1500
    285/75/16 BFG's
    2 Blaupunkt 10" vW1000 subs in Subthump box
    ProComp Level Lift & 3" rear blocks
    clgoch187......The 255/70/16's was one of the Tire Sizes that Chevy/GM Installed on the Factory 16in" Alloy Wheels.
    ^this is accurate. You can actually fit as big as 265/75/16 on your truck if it's 4wd, maybe even on 2wd
    Chuckie!!!
    Quote Originally Posted by clgoch187 View Post
    Yup. I'm guessing someone put smaller tires on it. 265s are the oe recommended size but a lot people go to the 285/75 that should be the biggest you can go with out rubbing( at least without any lift) on a 4wd. If yours is 2wd you probably don't wanna go any bigger than the 265 without doing a little research first. These should be a sticker inside your driver side door jam with the recommended size a tire pressure
    285/75 requires a leveling kit at the very least without rubbing.
    Quote Originally Posted by Bowtied View Post
    To help you, here's some Information"Specs"on both Tire Sizes, the 255/70's and the 265/70's....
    Tires: Tire 1 Tire 2
    Tire Size 255/70-16 265/70-16
    Section Width
    255 mm (10'') 265 mm (10.4'')
    Sidewall 179 mm (7'') 186 mm (7.3'')
    Tire Diameter
    764 mm (30.1'') 778 mm (30.6'')
    Rim Sizes
    16x7 to 16x9.5 16x7.5 to 16x10
    Circumference 2399 mm (94.4'') 2443 mm (96.2'')
    Revs per mile 670.8 658.8
    Speedometer Assuming that this is OEM Tire and Speedometer Readings are Correct >>> When Speedometer reads 60mph Actual Speed will be 61.1mph: 1.8% Faster.
    Aug 2010
    I had 185/75/16s on my or wheels with absolutely no rubbing on my 03 z71 before I leveled it and from what I can find the z71 suspension package had no change in ride height.
    Z71's are taller than the regular 4x4. Although, I wouldn't expect a 185 to rub on a geo metro. Let alone a z71 lol
    I have 285/70r16's on my 2001 HD2500, no rubbing issues...
    You're driving is WAY more offensive than my swearing, assjack!!!
    Quote Originally Posted by thrasher View Post
    those are almost the same height as a 265/75/16. They're just wider....
