    Default intermitant electric spook
    I have a 2002 Sub, awhile back my battery would go dead over night, which went on for weeks. I replaced the 3 year old one but the problem persisted, I had to leave a charger on over night. I put a meter from the disconnected ground to the ground wire, I pulled every fuse and relay I could find to no avail. Oddly enough a week or so later I forgot to hook up the charger, much to my surprise the problem had gone away. That was mid summer, just a few days ago it returned! I did quite a few net searches and found it seems to be an issue several others have or are experiencing, I only found one possible solution that was to re flash the computer. Looking for any other ideas before going to the dealer, I am tight on $$ having recently gotten off chemo and not back to work.
    Phil
    Happy 2 Wheeler!
    When you connected the meter from the disconnected ground to the ground wire, did you set the meter to DC-amp and what was the amperage draw?
    1993 964
    1996 318TI
    I used a volt meter looking for a drop when I found the circuit did not see any variation, what type of ammeter would be needed?
    Phil
    Happy 2 Wheeler!
    You need to use an amp meter (buy a cheap digital multi-meter, I've read where your harbor freight has them for $5.00)
    The only way you will find this is to read the current draw while pulling fuse.
    BTW, it is probably not the computer.
    Still have not gotten a meter, but had a shock today! When I lock my truck only the driver side door locks, all other are unlocked no matter how many times I hit the lock button. This is getting even more interesting.
    Happy 2 Wheeler!
    Quote Originally Posted by FireRed View Post
    buy a good meter that has the amp scale on it. over time this will save you lots of time trouble.
    start with the highest scale. then drop to where you get a reading. you should get less than 250 MA. that is .25amps.
    no key in ignition , doors closed doors locked . 15 min after shutdown with meter connected remove one fuse at a time until you see a drop. 10 MA or less is good...new vehicles do suck more sleep current than older vehicles.
    I recommend only high CCA amp batteries because of this fact. I now use 850 CCA batteries.
    it is possible the radio/amplifier is not shutting down common problem with some GM vehicles. this is usually the BCM.
