Results 11 to 13 of 13
    just got off the phone with a mothers window tint representative, the ones who did my tint many, many years ago... and once i described the problem he immediately knew what I was describing.... so apparently you are NOT supposed to use ammonia products on tinted windows, (my family has always used windex, however, i think it has only been in the recent years that ammonia has been incorporated into the formula) he said what it does is slowly removes the tint layer by layer over time, the best method is supposed to be soap and water... he said when you get your windows tinted they are supposed to notify you of this, however when i had this done 6+ years ago, i was never notified...
    he also said there is no reversing this process, it would have to be completely redone :/
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    Sr. Engineer Dana W's Avatar
    Dec 2011
    Chuluota, Florida
    Ammonia has been in Original Windex since day one. Windex multi-surface & glass cleaner does not have ammonia in it.
    Every time that I have had tint installed they gave me a few sheets of paper. one with all of the warranty info like batch and roll number of the film used. The other always had care instructions, like dont roll your windows down for a certain amount of time, dont use cleaners with ammonia. dont clean them with a brillo pad. I actually just found the info for my 95, I wanted to get the faded tint replaced under warranty. Unfortunately, the company was bought by another company that will not honor warranties pre 2005
