    Default Looking for a little Rumble in my 06 GMC
    Hey guys,
    I wanna get a muffler that gives my truck a little more rumble to it. Im havin a hell of a time trying to find one with the dual inlet and single outlet like the stock one is now. Just tryingto avoid getting the "Y" pipe. Any suggestions?!?
    -Dan
    ~Dan~
    Master Mechanic clgoch187's Avatar
    Aug 2010
    Gettysburg, Pennsylvania, United States
    I don't think your going to find a whole lot unless you to a dual in dual out set up or y pipe it before the muffler. You could also go with a cat back system and replace it all.
    I just got a Gibson ss dual cat back for mine, and I love it. Its still pretty quiet inside the cab but has a deep mellow tone, I can't stand the cab resonance you get with flowmasters.
    Also I think I've seen some suburbans and tahoes that y pipe the dual exit muffler before exiting behind the wheel....you might be able to swap them out
    03 Silverado 1500
    285/75/16 BFG's
    2 Blaupunkt 10" vW1000 subs in Subthump box
    ProComp Level Lift & 3" rear blocks
    It's a lot easier than it appears. Many aftermarket oval muffs can be run in either direction, so a dual/single setup works for you. A good example is the Magnaflow 12158, which is dual/single, fits where your muff is located, and is reversible. Available many places, including ebay for about $110. Flowmaster makes the same thing, too.Jim
    Aug 2011
    Long Island, NY
    Quote Originally Posted by buckmeister2 View Post
    Amazon on has the magnaflow for $100: http://www.amazon.com/Magnaflow-1215.../dp/B000CCFIYE
    2004 GMC Sierra SLT Z71, Truxedo Low Pro QT tonneau cover, Rhinoliner bed liner, Putco side rails, Weathertech window deflectors and floor mats, AMP Research bed extender, GMC cloth seat covers, light bar, lights and more to come.
    Aug 2010
    Aren't magna flows perforated tube? Running them backward would ruin the desired effect of the muffler. Also even on a chambered muffler, the baffles are designed to function in one direction of airflow...and reversing that would change the sound and add restriction to the exhaust system
    03 Silverado 1500
    285/75/16 BFG's
    Jul 2013
    Dolores, CO
    Quote Originally Posted by clgoch187 View Post
    exactly. Glass packs and "turbo" style mufflers are the only ones that are reversible unless otherwise specified. Most company's make dual in and single out mufflers. Flowmaster is one of them. Call summit or he's and they can get you a price and/or part number for the correct fitment that you desire without jerry rigging something else that doesn't belong.
    Chuckie!!!
    they post on their site that they can be reversed....so, you guys decide. If you cut open some of the perf muffs, you will see that the perfs are often multi-directional. I, too, had the same concern. But once I saw "reversible" on the description of many of their chambered muffs on their site, I stopped being concerned.
    Jul 2013
    Dolores, CO
    I wonder if anyone here has done any flow test on them in both directions as well as other mufflers. I'd be interested in seeing the results.
    Chuckie!!!
