    Default 99-06 silverado door check replacement
    replaced mine after the driver side bushing went out and kept "popping" when i open or closed the door...
    only 3 bolts hold it all together, but you have to remove the door panel to get the old one out and the new one in. one bolt (visible), the other two bolts, underneath the rubber grommet in the picture, very easy job!
    before
Name:	IMG_4147 (480x640).jpg
    after
Name:	IMG_4169 (480x640).jpg
    before
Name:	IMG_4149 (480x640).jpg
    after
Name:	IMG_4168 (640x480).jpg
    new(left) old(right)
Name:	IMG_4165 (640x480).jpg
    the p.o.s. bushing that was dead
Name:	IMG_4167 (640x480).jpg
    only thing is.... the new ones are already creaking!!!
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    White lithium grease will lubricate the new hinge, and stop the creaking. Good job on the repair, I know you saved yourself some money in labor.
    Jr. Engineer BRB46's Avatar
    Apr 2011
    Western Mass
    Nice write up. Is the replacement one OEM or an aftermarket one as the design is different.
    2006 Silverado 1500 5.3L ecsb Z71,afe pro s dry air filter, color matched tailgate handle and bezel,color matched front bow tie, led interior illumination, 5000K HID lows, Black powder coated wheels, Blacked out body side moldings, Rough Country 2.5" level/lift kit, Magnaflow muffler
    Quote Originally Posted by BRB46 View Post
    it is an oem replacement, ive been looking at trucks door checks when i was pulling in cars at discount tire, and it seems all trucks after 02, came with this new "updated" design
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    4.10 gears
    Audio:
    Head Unit: Alpine
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    $71 bucks from the dealership... I did my driver door yesterday
    quick update on this, my hinges have yet to stop creaking.... they never creaked with the old ones, just popped as the bushing was dead, but i have yet to see the day these hinges become quiet, very annoying...
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    4.10 gears
    Audio:
    Head Unit: Alpine
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Mine don't creak, 250k, try some silicone spray or graphite spray...., WD40 will rinse off in the rain
    already used some white lithium grease, but it doesnt get into the bushing eye because it is so tight...
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    4.10 gears
    Audio:
    Head Unit: Alpine
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
