    Default Suburban bad brakes
    88 subby......brakes are bad.....pedal goes to the floor......if i slam on them i believe the rear brakes engage.....could it be air in the lines...HELP
    hey buddy.....if I was worried about gas mileage Id have you tuning up my ten speed....shut up and change the plugs please.
    moved post to proper sub forum
    Quote Originally Posted by biggsmiley View Post
    Yes, if you had them apart. If not been worked on lately, you have a leak somewhere. Look on the ground/floor for a puddle of fluid, or crawl under and look at the inside of the wheels.
    Sr. Mechanic poncho62's Avatar
    Sep 2013
    Hanover, Ont, Canada
    Pop the top on the master cylinder and see if the fluid is way down. Id one side is empty, you likely have a leak. If its full, you may have a bad master cylinder....or air in the lines
    [B]1997 GMC
