Results 1 to 10 of 15
    Sr. Mechanic
    Oct 2013
    weedsport, NY
    Default tranny noise????
    I have an 06 2500 HD, 4x4, and it has a whining noise when running. I checked the fluids and all are ok. I thought it was the power steering pump, but now I'm not so sure! Anybody ever change the pump in the tranny? Can that be done without a total tranny job?
    Sr. Mechanic
    Oct 2013
    weedsport, NY
    GREAT! I got the only truck in the world with this problem!!!
    Need more details man...does it make noise all the time?change tone when cold/warm?is it up front?in back?can you hear it in cab?when your turning?miles on truck?etc...what it COULD be is the power steering pump low on fluid,fuel pump whine...let us know more details
    Line-X'd Bed
    5.3L Flex Fuel
    Factory Black Running Boards
    2" Rough Country Leveling Kit
    EGR In-Channel Vent Visors
    Exterior PLUS Package
    Interior PLUS Package
    K&N Drop-In Air Filter
    Bowtie Mud Flaps
    Cat-Back Dual Exhaust
    Black Bowties
    DeeZee Toolbox(Debadged)
    ProFlaps
    Towing Mirrors
    Next Planned Mods
    Bigger Tires
    Aftermarket Rims
    I've changed a front pump before in a 4l60e, but you have a 4l80e so I'm not sure it's the same thing. The front pump is easily removed, by standing the transmission on it's nose and the front pump is right on top. It's held in with about 12 bolts, my replacement pump cost about $49 new from GM.
    Sr. Mechanic
    Oct 2013
    weedsport, NY
    So I gotta drop the trannie! Well aint that special! Chevyboy, aint no fuel pump whine like this! I thought it might be the power steering pump, but like I said, all fluids are fine an full! Its all the time,(when the trucks running) no matter the weather or the temp!
    Even if fluids are fine and full,it still could be pump!
    Line-X'd Bed
    5.3L Flex Fuel
    Bowtie Mud Flaps
    Black Bowties
    ProFlaps
    Towing Mirrors
    Next Planned Mods
    Bigger Tires
    Aftermarket Rims
    I would invest in a cheap mechanics stethoscope and start listening around the motor. As mentioned above, just because the fluid level is good does not mean the pump is. You can also just use a long screw driver with and hold the end to your ear. But, a stethoscope is easier to get into tight spots. I had 2 new ps pumps with new fluid whine until I put an additive in the fluid. it could be any of the pulleys making the noise.
  8. Likes ChevyBoy2009 liked this post
  9. #8
    Quote Originally Posted by zuki82 View Post
    get a small plastic flex hose like 1/8 inch . stick in your ear then tape a stick to the other end and with the engine running probe for the location of the sound.
    the whine I had was the PS fluid needed replacing. I used prestone [gm] power steering fluid with the seal conditioner. after sucking the fluid out 2X the pump makes no sounds..
  10. Likes zuki82 liked this post
  11. #9
    Sr. Mechanic
    Oct 2013
    weedsport, NY
    Well, I took it to the mech. up the road and he used his stethoscope and tracked it down to the steering pump!! That's a big relief!
  12. #10
    And what did we tell you?!
    Line-X'd Bed
    5.3L Flex Fuel
    Bowtie Mud Flaps
    Black Bowties
    ProFlaps
    Towing Mirrors
    Next Planned Mods
    Bigger Tires
    Aftermarket Rims
