    Default Rear axle snapped
    A couple nights ago my 1992 Chevy 3/4 ton silverado got stuck in a decent sized ice shelf at the approach of my drive-way, after a couple hours of trying to shimmy it out, I noticed the passenger side rear wheel had stopped spinning. I figured it had something to do with the rear wheel differential and didn't think much of it, so I went back inside to warm up and evaluate my options. I came back outside and tried to shimmy it out one more time by putting it in reverse, then drive, then reverse and just repeating that until I noticed the rear passenger side wheel had fallen off! Split right at the axle seal! I had it towed to a mechanic and he said it would be around $2,000, does that seem about right?
    The weird part is that there was no clunking or grinding prior to the axle breaking.
    If the end broke off the axle, a used axle shaft at a junkyard would be less than $100.
    You probably have some damage to the rear brake on that wheel. That shouldn't be any more than $200.
    If the axle housing is ok, $2,000 is high, if the housing is damaged and you need a complete rear axle assembly, may not be too bad a price.
    But, look at it this way, better to have come off in the drivewat than at 75 mph on the highway.
  3. Likes reggiecab2000 liked this post
  4. #3
    Those were my thoughts too! Could have been a lot worse.
    Thanks very much RayVoy for that helpful information
  5. #4
    since it broke in the driveway I see no problem using a scrap yard axle and replace the axle bearings/seals.
    I had an axle replaced it got bent in a small accident vehicle hit my driver side rear wheel.
    I bet the brakes are ok.
    a relative had this happen on a pontiac doing 60 mph...
  6. #5
    I had some new 31 spline axles made from Moser last year, $187.00 each and they were brand new. They make them per order, so they are custom made to your order. Just an idea.
