    Default Low oil pressure
    This is my last time going to a chevy dealership. I had my 2010 chevy crew cab in three times over the last year for replacement of the fuel sensor, oil pressure sensor, leaking trans cooler lines, ect... For almost 1700 dollars in repairs. I asked for some goodwill on this last bill an got the run around. I then asked for a for sale sign. I'll be buying ford from here on out. Gm warranty is a joke!
    There was a guy standing at the service desk with his new truck, 2 weeks old already in the shop. I told him good luck, you just got screwed by GM. The faces of the people at the desk almost made the sting of the lasted bill almost worth it. Almost. The know the sensors are junk on all there trucks.
    Sep 2013
    Hanover, Ont, Canada
    Sorry about your luck.......
    1997 GMC
    I am sure the ford will be a better truck than the gm 2010. most are very happy with these new ford trucks.
    good luck.
    Quote Originally Posted by Mathewsman View Post
    wait a second. how far were you out of warranty? most gm service parts carry a 12 month 12,000 mile parts and labor warranty. were the same sensors replaced? I have to say, if you went to a dealer in stead of a local trans shop or repair shop for a leaking trans line then you probably paid double the price. Most repair shops in my area are $65 an hour compared to $100 at a dealer.
    I'm sure you realize GM does not make the sensors------------------Ford probably buys theirs from the same supplier.
    Hmmmm, just noticed only 1 post................you probably won't be back.
    Yeah, this is his first and only post...just joined. Why would someone join a forum just to post that they are leaving the ranks? Maybe reasonable, but I would not be surprised to find that there is a whole lot more to this tale.
    oh, he said he was going to buy a ford. I was plowing in a brand new f250 last week. Nice truck, I did not care for the dash, but whatever. Anyway, the truck had 200 miles on it when I got in it. As I was plowing I noticed that the horn honked when turning the wheel. Then it just stayed on until the horn burned out. Then I looked down and the DIC was going nuts, changing languages, units, resetting the oil life monitor. Then the airbag light came on. This in a truck with under 500 miles on it! My point is that no matter what you buy you are going to have some issues here and there. The issue on the ford ended up being pinched wires in the steering column. If you are taking your truck to the dealer for work that is not covered under warranty then in my opinion you really can't complain when they ask for your first born as payment. 99% of people know that the dealer labor rate is very high and the price of parts is marked up even higher. After I took it in for the first sensor I would have gone to a local shop next time I had an issue (if I could not have done the work myself) and had it done. The parts would have been half the price and the labor 2/3 of the price.
