Thread: Timing issue?
    Jul 2013
    Dolores, CO
    I recently replaced the intake gaskets on my wife's 99 Tahoe (5.7/auto). After doing so I had a reputable shop set the timing since I don't have that fancy computer. Now 3 days or so later the "service engine soon" light comes on. The truck feels like it has not low end guys at times. This sounds like timing issue to me, but I would like a second, third, or 100th opinion lol Here are the codes that we pulled: p0420/p0430. I've read that these are generally O2 sensor or cat converter issues, but again I would appreciate confirmation from those of you more knowledgeable than myself. Thanks in advance!
    Attached Thumbnails Attached Thumbnails image-216059151.jpg   image-3231037309.jpg
    Chuckie!!!
    Jul 2013
    Dolores, CO
    Dang. Nobody has any ideas?
    Chuckie!!!
    Sr. Engineer
    Oct 2010
    Indianapolis, In
    Intake leaking?
    Jul 2013
    Dolores, CO
    Intake leaking?
    no coolant in the oil or vice versa, and I haven't spotted any fluid seeping. I've been keeping a pretty close tab on it for about a week
    Chuckie!!!
    Before the intake replacement was there oil or coolant getting in the the cylinders? Either burning can quickly damage the Cat or the O2 sensors. My Tahoe has that code because of a bad cat which I'm replacing in June.
    Just for the heck of it I would take a can of carb cleaner and spray around the intake while it was running listening for rpm increases.
  7. Likes zuki82 liked this post
  8. #7
    Jul 2013
    Dolores, CO
    Yes, there was coolant in the oil
    I'll give it a try
    Chuckie!!!
