Results 1 to 8 of 8
    Newbie Hatem is a glorious beacon of light
    Sep 2008
    Saudi Arabia, Dammam
    Default Problem in GM Trucks Radio
    Hi experts,
    I just bought used 2004 Tahoe; the radio in FM mode doesn’t set to frequencies such as 101.0 MHz. it will set to 100.9 or 101.1. And in the AM it will step 10 by 10 for example 540 550 560,
    Is there any solution or set up to have FM 101.0 102.0 MHz??
    Thx
    Administrator Steve has much to be proud of
    Dec 2004
    Arlington, Texas, United States
    10 Post(s)
    1 Thread(s)
    Quote Originally Posted by Hatem View Post
    Hi experts,
    Thx
    Huh, do any modern radios let you set the channel to an exact even tenths of a decimal? I think that's how stereo works, they send one signal out at 101.09 and another out at 101.11 and when you tune into 101.1 you get both signals ... ala stereo.
    Steve
    02 Chevy Trailblazer LS (110K+ miles - loaded except for 4WD - WRECKED!)
    99 Chevy Cavalier LS (105K+ miles - commuter car)
    78 Chevy Suburban Silverado (454, 3/4 ton)
    62 GMC 3/4 ton Pickup (350 police interceptor)
    Search Before Posting | Fill out Your Profile & Signature
    My Trip to GM Detroit | Meeting w/ GMC, Buick & Cadillac
    Replacement Chevrolet Tires
    Sep 2008
    Truck has USA Specs will have only 1019 MHz, but here in the middle east we have the exact same radios can set to 1020 MHz I WANT TO HAVE THAT IN MY SUV :(
    Sr. Engineer zippy is a glorious beacon of light
    Dec 2007
    SoCal
    There's nothing wrong with your radio, it's not set to the proper country code. Is it a recent import? By using an OBD-II scan tool, the radio set up procedure can configure the country code. Then, your radio will display the correct frequencies.
    The Chilton's service manual and Chevy Owners Manual don't contain the codes by country. But, your area GM service facilities should be familiar with the radio set up procedure. Alternately, if you have a friend with a working GM radio, you can use a scan tool to see the correct country code for your location.
    Are we having fun, yet?
  5. #5
    Dec 2004
    10 Post(s)
    1 Thread(s)
    Quote Originally Posted by zippy View Post
    Awesome, I guess I don't travel enough internationally!
    Steve
  6. #6
    Sep 2008
    Great!
    I understood that if I bring a local spec radio (from a local truck) the problem will not be solved because the PCM will keep sending USA country code << need your answer about that thought.
    1- One of my friends uses EFI Live tuner playing with the 3rd and 4th GEN engines. Can he do that for me using his Tuner & Scan tool?
    2- I don't want to go to the dealer to get my country code, is there any other way to find that code?
    THANK YOU
  7. #7
    Dec 2007
    SoCal
    Quite possibly, but I'm making a lot of assumptions about your radio. You won't know until you try.
    Yes, assuming your friend's scanner works and his radio works in the area and it's similar to yours. As I said earlier, have your friend look at the country code on his radio. The first entry in the radio set up menu should be the country code -- write down the code. There may be more than one radio ID's listed, there were several available in 2004. If so, since we don't know which ID is your radio, write down the radio ID and the country code for each radio ID listed.
    Then attach the scanner to your truck and put the codes into your radio. (Match code to radio ID, code by code, if applicable.) If your radio has the security light on, then re-code it by launching the Learn VIN routine which is the last item of the radio set up sequence. As I said earlier, this all assumes your radio's country codes are programmable and compatible with your local broadcasts.
    If this doesn't work, you can try entering random country codes. It could take some time. Just write down the starting codes before your begin and keep track of what you're doing.
    Good luck and please let us know if this works for you, we're trying something new.
  8. #8
    Sep 2008
    sure will let you know, and thx for helping be (two brains better than one)
Similar Threads
  1. radio problem
    By dhnewman in forum Audio / Video Electrical
    Last Post: 12-09-2008, 02:47 PM
  2. 07 Silverado radio problem PLEASE help!
    By hadleymn in forum Audio / Video Electrical
    Last Post: 09-28-2007, 10:00 PM
  3. Sirius radio connected to radio with XM
    By HitchHiker in forum Audio / Video Electrical
    Last Post: 09-18-2007, 09:55 PM
  4. 2000 Delco radio problem
    By Cableguy in forum Other GM Cars
    Last Post: 08-25-2007, 11:17 PM
