I need help figuring out what this clunking noise is when I turn a corner.
I only notice the noise or clunk when I'm turning the truck at slow speed. It happens mostly when I turn to the right but it does clunk once and a while when turning to the left.
Any help is greatly appreciated.
What truck are you working on?
2 wheel drive or 4 wheel drive?
Is it when you are moving slow or at any speeds?
Where is the sound coming from?
Gary
99 K 1500 Suburban
78 Silverado Big 10 w/factory 454
1977 Formula
1976 Trans Am
1980 Honda CB900 Custom
Welcome to the site! If it's repaticious clunking you hear and also feel in the steering wheel (even though there is no play in the wheel itsef) then it could be the notorious intermediate steering shaft. I had mine replaced under warranty at the dealer my wifes 2001 suburban does it as well. What are you driving?
Darcy
Washington State
my 04 does what your talking about dwill i wounder if i still could get that fixed threw warranty probably not
2004 chevy silverado "northwest edition" lifted on 35's
1990 cherokee lifted on 32's
I am driving a chevy 1500 2x4.
The noise sounds like it is coming from the rear and I only notice it at slow speeds.
Darcy
Washington State
OK thanks...any ideas what it may be?
What year Chevy? 10 bolt rear or other? Open diff or Gov-lock or other? Any sign of problems in the u-joints on the driveshaft? I might check the brakes, especially if you have drum brakes for any hardware problems. I might also pull the diff cover and make sure the spider gears (and the rest of it) look ok. Maybe check the diff fluid to see if it has enough. I would also probalby go through the suspension carefully and look for loose parts (like a missing shock absorber bushing or a sway bar end link if you have a rear sway bar).
'98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
'92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
"My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
Bookmarks
