    Default Keeping my regular headlights on at the same time as the hi-beams
    I know some people around here have done this. I remember something about a relay but what all do I need to do this conversion and how difficult is it?
    I want my regular headlights to stay on even when I flip on the brights.
    I'd like to do this the same time I replace my headlight housings and my grille which could be this weekend or the next.
    Here's a Web Site, that sells the 4-Hi Headlight Mod Conversion Kit,
    http://www.stylintrucks.com/parts/hi...x00129d-.aspx#
    I did this: http://www.chevyavalanchefanclub.com...tdrlnstall.pdf . @Enkeiavalanche posted the link some time ago. It cost me around $4
    I asked the same question on another forum (a computer/tech forum with a small automotive subforum) and someone there linked me to a site where people were simply grounding a single wire that was previously ungrounded. Is that recommended and/or safe?
    Perhaps MADS99, er @99'HEARTBEAT, can enlighten us.
    Clint....after I installed the 4-Hi Headlight Mod Conversion Kit above on my Truck, I then heard, that by locating on the Passenger-Side Headlight, the Yellow Wire, and Splicing into it and then adding some of the same Gauge Wire, and then running that wire to a Solid Ground, in the end it gives you the 4-Hi Mod....and as far as I know, the ones that have Done this Mod "Splicing into Yellow Wire" have had no problems....
    LMC truck has a kit for this, LMC truck.com
    ​DAVE
