Is it possible for a Z71 to have a 3.43 gear ratio? I've been looking and I cant find anywhere that shows a Z71 with a 3.43. I'm hoping this is a mistake. I looked in the glove box where those numbers are listed and it showed the 3.43 number. I was under the impression that i had a 3.73. Where could i get a 3.73 G80 for a good price? I need it for trailering and stuff. Oh, and do i need to make any modifications to the front transfer case if i swap ratios?
2006 Silverado Z71 - 97,000 - totaled, RIP
2006 Silverado Z71 - 70,000 (K&N 77 Series CAI, PowerAid TBS, Magnaflow dual rear exit, 33x12.50 Mickey Thompson MTZ, Tuff Country Torsion Keys, Tuff Country Add-A-Leafs)
I'll keep my money, guns, and freedom. You keep the Change.
If that's what the RPO codes say, then I'd be inclined to believe that was what it left the factory with. Maybe the original purchaser special ordered it with a 3.43, or just the luck of the draw. Only other way to check gear ratio would be to count tire rotations vs. driveshaft rotations or to open the diff count the teeth on the ring and pinion gears.
3.73 G80 seems to be pretty common, especially in Suburbans. If you want to go the route of finding a junkyard axle, you'll just have to shop and compare until you find one you're willing to pay for.
AS for the front diff, you have to do something to it when you change the rear gear ratio. Either permanently disable/remove the front drivetrain and convert to 2wd, or change the front diff ratio to match the rear.
'98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
'92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
"My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
Any gear combinations possible. 3.43 is an optional gear for all Light Duty GM trucks.
If you regear the rear you'll need to regear the front diff, and recalibrate your speedo either by mechanical means or electronic. The transfer case needs no changes.
Look on line for gear sets at parts vendors. Most likely though your best deal will be buying a set of gears from whatever shop you decide to have do the work, most shops tack on an extra 10 to 25% for shop fee's or labor when carrying in parts. Look to spend between $600 and $1000 for a regear.
Tim
2011 Silverado 1500 LT
2008 HHR LT
1999 Tacoma SR5 TRD 4X4
1993 Jeep Wrangler
1991 Toyota Rock Crawler
2009 Harley Davidson Nightrain
2004 Harley Davidson FLHT "Bagger"
2003 Glastron GXL Bowrider
i believe there should be a little plate on the diff cover being held by two of the bolts that says your gear ratios. and if you change the rear gears you absolutely have to change the front
PETE
95 GMC Sierra 2500
3" Body Lift, 33" Goodyear MTR's
5.7L 350 TBI Edelbrock SDT Exhaust, Flowtech Headers, K&N Intake
Sold :(
1999 Jeep Cherokee, 3" Rustys lift, 33" BFG MT's, locked, armored: Rolled :(
2000 Jeep Grand Cherokee Limited. K&N Intake, Custom Kolak Exhaust
Contact this GMTC Moderator for any problems or questions you may have
Join the GMTC Facebook Group!!! Join Here
Yes you can have a Z71 with 3.43 gears....my 07 Z71 came stock with 3.43's. I'm in the process of switching to either 4.11's or 4.56's. There's another good post about gearing going on right now...
And yes, whatever you swap the back out to you MUST do the same to the front.
there is a chart for the optimonal gear ration http://www.4wheelparts.com/aux_incl/gear_ratio.html
2004 chevy silverado "northwest edition" lifted on 35's
1990 cherokee lifted on 32's
What effect would it have on my truck if i ran 35's on my 3.43 gears? Would it kill the tranny or something? i REALLY want to lift the truck, and money wise, i'm over half way there. I'm eventually going to change out the gears too, but that'll probobly be in about 3 years from now or so.
AHA! i found a website that sells diffs. what is a spline? like 26 or 28?
gears aren't that expensive its just the install that's the hard part if you don't know what your doing you can really mess things up
Bookmarks
