Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Jr. Apprentice J-Black'01Silverado is a glorious beacon of light
    Sep 2008
    Default Need help finding a Black Blow Tie Emblem
    Occasionally I see trucks with black emblems and I've searched on the internet and cant not find one anywhere. I found one that has a red trim around it, but I would like an all black one. Please help!
    Legend Springthing has a reputation beyond repute
    Aug 2008
    East of Branson, Missouri
    1 Thread(s)
    I think it's more a question of paint, not so much where to buy a black bow tie.
    Just give the regular one a good scuffing then hit it with some black spray paint.
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
    Master Mechanic adidasboy918 is a glorious beacon of light
    Aug 2008
    Yucaipa, CA
    check on ebay. i think i saw a black bow tie lastnight on there.
    Peter
    2007 Silverado LT Crew NNBS 5.3
    Stock 20"
    Black Powdercoated Billet Gas Door
    LineX Bedliner
    Go Rhino Dom II Bars
    Work in Progress
    1952 Chryler 2dr Windsor } Mine and Dad's
    Former Cars
    2000 civic hx Moded
    1993 Probe simi moded
    1985 Nissan 4x4 Kingcab
    So*Cal Group
    Legend cascott325 is a glorious beacon of light
    Aug 2008
    Lawrenceburg, Kentucky
    go to your local hardware store, and get a soft scrub pad and some krylon spray paint. you will probably have to pop all of the little plastic rivets out that hold the plastic shroud on under your hood so that you can access your bowtie. you might need a flat screwdriver to help you pop out the emblem but it isnt hard at all. you should be able to figure it out in a matter of seconds. take the soft scrub pad (simmilar to what you get off the back of a dish sponge) and scuff it up nice and evenly. you dont have to apply alot of pressure b/c it will show when you paint. get a degreaser and wipe it off, then wash it with water. when its all nice and dry, you can apply paint. make sure you shake it well and hold it about 8 inches away from the emblem. smoothely and evenly coat the emblem until covered. if you have a wire shelf or basket to set it on, you wont have the spray build up like you will if you were to place it on cardboard. allow 20 - 30 min to dry and apply again. put 2 - 4 coats if you think its necessary. i didnt put a clearcoat on mine but you can if you want. i think i used a semi-gloss but you can use what you want. lightly wetsand the emblem when you're done. its not safe to pop the emblem back into place or even sand it until you give it about a day to harden... believe me, i made the mistake and got finger prints and had to do it all over again. after you're done, you should ben good to go.
    2000 silverado with a 5.3l v8, shorty headers, upgraded plugs, 10 mil wires, magnaflow high flow cats, flowmaster 80 series muffler(2 in 2 out) w/ 18 inch stainless silverline tips. i have a k&n CIA. its a 4x4 z71 offroad package. Ls model.
    extended cab 160k miles, truxedo low profile bed cover, diablo sport predator tuner.
    reman tranny @ 130k miles
    Chris
  5. #5
    Sr. Engineer
    383man is a glorious beacon of light
    May 2008
    Chehalis, WA
    Quote Originally Posted by cascott325 View Post
    good info above, the only thing that makes it easier is you don't have to remove the bowtie to paint it, just buy a 10ft drop cloth from walmart or wherever, about 3 bucks, and some painters tape, tape around the tie, then hang the cloth over the whole front of the truck, cut a whole around the bowtie, then tape the cloth to the truck around the tie so you have a dropcloth covering the truck, and just a hole to paint the tie, way less intrusive, and those ties are easy to break when taking them off, i did 3 coats and it came out great, i didn't use a clear coat either cause i wanted that dull tone to it, and it hasn't chipped yet, had it for about 4 months that way, i did front and back same way, and i'm thinking about doing the steering wheel bowtie lol.
    2009 silverado Crew Cab LTZ Z71 4X4
    6in FabTech suspension lift
    35x13R18 nitto terra grapplers
    6k and risin
    Previously owned vehicles-
    2007 silverado ext cab LT 4x4
    2001 silverado std cab 2wd
    1990 toyota pickup
    1989 Trans Am GTA
    1957 Chevy Pickup stepside
  6. #6
    Jr. Mechanic TylerR04 is a glorious beacon of light
    Jan 2008
    Bloomington, IN
    I used Krylon Fusion [COLOR=blue! important][COLOR=blue! important]silver[/COLOR][/COLOR] metallic color and Krylon clear glaze. I did 4 light coats of the color to make sure there were no runs and waited about 30 - 45 minutes in between each coat. Same with the clear glaze. The can says that one coat of the glaze is the equivilant of 3 coats of clear coat. I also let the bow tie sit over night to make sure everything was dry completly. I think everything turned out really well and it only cost me 10 bucks. Just go buy black insted of silver and you don't have to sand of scuff up the emblem. Just wash it and make sure it's dry.
    Ty - 2004 Tahoe Z71
    www.myspace.com/jasonsturgeonmusic
  7. #7
    Aug 2008
    i've beel thinking of putting a 1/8 inch silver pinstripe about 1/4 inch from the outside edge of the emblem or i have also thought about saking silver paint and putting some artificial rivets on to make it look a little more rugged
    Chris
  8. #8
    Sep 2008
    Thanks everyone, painting it sounds a lot a better than dropping 100 dollars or so.
    Jon- North Carolina
    2001 Chevy Silverado(loaded, Z-71)
    *2" Leveling-Kit(Rough Country)
    *33" Nitto Terra-Grapplers w/ 17in Dick Cepek DC-1 Blacks
    *AEM Brute Force Air-Intake
    *Custom Exhaust:
    Flowmaster 10-series Muffler:
    3-1/2" dual angle-cut tips coming out before right rear tire
    Also with the addition of a "cut-out"
    *Completely re-done sound system
    2005 Chevy Tahoe(laoded Z-71)
    *daily driver
  9. #9
    Master Mechanic CarpenterGuy is a glorious beacon of light
    Jul 2008
    Leeds, Alabama
    Yeah, a buddy of mine sanded, primed, and painted his.
    2006 Silverado Z71 - 97,000 - totaled, RIP
    2006 Silverado Z71 - 70,000 (K&N 77 Series CAI, PowerAid TBS, Magnaflow dual rear exit, 33x12.50 Mickey Thompson MTZ, Tuff Country Torsion Keys, Tuff Country Add-A-Leafs)
    I'll keep my money, guns, and freedom. You keep the Change.
  10. #10
    Aug 2008
    1 Thread(s)
    Quote Originally Posted by J-Black'01Silverado View Post
    Send me $50 and your old emblem and I'll send you a black one back..
    Steven
    "The Sarge"
    7.4 454 Vortec, 4WD
Similar Threads
  1. ECM-B Fuse Continues to Blow!
    By Big6ft6 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 04-20-2010, 11:13 AM
  2. will running one tire smaller(spare) blow front diff?
    By kawasaki_kid in forum General Chevy Tech Q&A
    Last Post: 01-25-2010, 12:24 PM
  3. ati anti blow?
    By azdrtdog in forum Performance & Fuel
    Last Post: 04-07-2009, 08:45 AM
  4. blow though
    By 00loudchevy in forum Audio / Video Electrical
    Last Post: 01-05-2009, 09:08 PM
  5. In Iraq got a ? so i dont blow $$$$
    By cg31313 in forum Lifted & Offroad Suspension
    Last Post: 09-26-2008, 03:09 PM
