Results 1 to 10 of 10
    Sr. Apprentice OE812 is a glorious beacon of light
    Apr 2008
    Louisiana
    Default Low Fuel Notice at Message Center
    My low fuel notice illuminated with fuel at 1/8 tank. I proceeded to fill the tank which took an unexpected 25.65 gallons of fuel on a 26 gal tank. Evidently the sensor is bad and need to know what and how to fix.
    2001 Chevy Silverado LS Extended Cab
    Legend retired2001 is a glorious beacon of light
    Nov 2006
    Canyon Lake, Texas
    My "LFL" comes on when I get about the same place. I have found that I usually have about 3 gal. left when it comes on. I usually fill it ASAP, as I don't trust it, although I don't know where the sensor is.
    2010 Z/71 Colorado C/C
    Black 4X4 w/5.3L V8
    2007 Winnebago Adventurer
    w/8.1L Chevy & Allison 6spd.
    Canyon Lake, Texas
    Apr 2008
    Louisiana
    Yeah. Usually 3 gallons of fuel left when the low fuel light comes on. But less than 1/2 gallon? You are right; don't trust it.
    Sr. Apprentice thekingsphance is a glorious beacon of light
    Sep 2008
    Fairfield, CA
    Default Low fuel light
    I have a very similar problem but I think it's worse on mine. Whenever I fill up, the needle spikes up and down intermittently along with the low fuel light.It does it about every 5 to 20 minutes. and then after I burn a little gas, it starts spiking less often and sometimes not at all and reads more accurately. What the heck is going on here. Anyone??
  5. #5
    Newbie gearjamminjake is a glorious beacon of light
    Oct 2008
    St. Louis, Mo.
    Quote Originally Posted by thekingsphance View Post
    that problem is typical for our trucks. most trucks around this year range due that. i've been told that it is the float sensor in the tank that is the culprit. if im not mistaken that sensor is part of the fuel pump and all has to be changed to fix the problem. i dont think its a huge deal just more of a pain in the butt than anything else.
  6. #6
    Sr. Engineer zach45 is a glorious beacon of light
    Apr 2008
    staten island new york
    same here... but i was told my tank is 22... i just put 26+ in
    08 5.3 silverado...toyo m.t 33 12.50 18 rockstars...leveled with 2" blocks...cherrybomb catback...6k hids
  7. #7
    Legend Springthing has a reputation beyond repute
    Aug 2008
    East of Branson, Missouri
    1 Thread(s)
    Quote Originally Posted by zach45 View Post
    Wow! Did you SHOVE the gas in there!?
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
  8. #8
    Jr. Mechanic EagleTalons is a glorious beacon of light
    Oct 2008
    Montana
    No he uses an air compressor to pressurize his gas to put it in there. So it eliminates the use of the fuel pump.
  9. #9
    Apr 2008
    how you know about my gas compressor...
    but when i fill up... I FILL UP
  10. #10
    Newbie cope_75 is a glorious beacon of light
    Oct 2008
    I have had the same problem, it is the acending unit going out on you, evidently it will stop working all together. You can change it yourself (drop the tank and all that work), have a shop do it ($500+) or keep up with the odometer -- I go 380 and filll up. But hey I am lazy!!! LOL!!
Similar Threads
  1. Change oil on message center!
    By Chango in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 05-23-2010, 05:24 PM
  2. Message Center Battery Light
    By trapper_canada in forum General Chevy Tech Q&A
    Last Post: 04-20-2010, 01:19 PM
  3. Suburban Message Center: Low Coolant
    By BurtsBurb in forum General Chevy Tech Q&A
    Last Post: 02-16-2009, 11:15 AM
  4. active fuel mgt. technology/driver info center
    By adamant in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-25-2009, 10:49 PM
  5. 2500hd silverado low fuel message
    By Micksauto in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-07-2008, 08:45 PM
