Results 1 to 6 of 6
    Newbie joeyd208 is a glorious beacon of light
    Sep 2008
    Question 84 chevy 4x4 jerks
    hey i have a 84 chevy scottsdale 1/2 ton 4x4 anyways when its in two wheel it drives nice but once i lock the hubs and use 4 wheel it jerks real hard like the front and the back arent workin with each other i dont know if the front or the rear diff's have ever been changed or not?? if someone has a way to tell if they have or not please let me know or if you think you know whats wrong please let me know ok
    Jr. Engineer mehoff400 is a glorious beacon of light
    Aug 2008
    are you putting it in 4 L and are you doing this on pavment
    2004 chevy silverado "northwest edition" lifted on 35's
    1990 cherokee lifted on 32's
    Legend
    Pete95Sierra is a name known to all
    Jan 2008
    Morristown, NJ
    if its on pavement it will do it, also are your tires different sizes by chance?
    PETE
    95 GMC Sierra 2500
    3" Body Lift, 33" Goodyear MTR's
    5.7L 350 TBI Edelbrock SDT Exhaust, Flowtech Headers, K&N Intake
    Sold :(
    1999 Jeep Cherokee, 3" Rustys lift, 33" BFG MT's, locked, armored: Rolled :(
    2000 Jeep Grand Cherokee Limited. K&N Intake, Custom Kolak Exhaust
    Contact this GMTC Moderator for any problems or questions you may have
    Join the GMTC Facebook Group!!! Join Here
    Master Mechanic CarpenterGuy is a glorious beacon of light
    Jul 2008
    Leeds, Alabama
    jack the truck up and put all four corners on jack stands (using 4 stands of course) and have a buddy watch the front and back tires as you turn the truck on and let the tires spin a little (not fast) and mark the tires with something on the same side (liek tape on the bottom of both tires) and after a while if they arent in the same position, then there's different diffs. I had to do that on a buddy's truck.
    2006 Silverado Z71 - 97,000 - totaled, RIP
    2006 Silverado Z71 - 70,000 (K&N 77 Series CAI, PowerAid TBS, Magnaflow dual rear exit, 33x12.50 Mickey Thompson MTZ, Tuff Country Torsion Keys, Tuff Country Add-A-Leafs)
    I'll keep my money, guns, and freedom. You keep the Change.
  5. #5
    Sep 2008
    well its in 4 hi and yeah its on the pavment if i do it on dirt it does the same **** it jerks back and forth real bad i never noticed it till i used the 4 wheel durin winter and it went from ice to pavement then it started to do that? so what you mean mark the same side tires?
  6. #6
    Legend Crawdaddy has a reputation beyond repute
    Feb 2007
    1 Post(s)
    NEVER USE 4 WHEEL DRIVE ON DRY PAVEMENT. That's one quick way to kill drivetrain components. Also, like Pete said, are you running the same size tires on the front and rear. Just because the tire says it's a 31 doesn't mean that the final height is 31". It can vary by manufacturer. Also, if one set of tires is worn more than the other, that can cause binding because the rolling diameter is different.
    Christopher
    1991 Chevy Suburban 1/2 ton 2WD w/ chevy SBC 350-3/4 ton drivetrain upgrade w/4.10 gears 194K miles
    2005 Saturn ION-2 Stock 200K miles (In 6 years...ouch)
    1982 Bronco, 1993 Bronco, 1971 M35A2 Deuce and a Half
Similar Threads
  1. Shuts off during idle and at times jerks while driving
    By chevyman1980 in forum Performance & Fuel
    Last Post: 11-30-2008, 02:19 AM
