Closed Thread
Results 1 to 5 of 5
    Newbie dcrawford999 is a glorious beacon of light
    Sep 2008
    Default XM Radio components [Expired Topic]
    I have a 2006 Equinox with an XM capable radio (I have an XM button on the radio). However, the components aren't there. There is no XM receiver/tuner. Can anyone that has/had XM in there 2006 Equinox post the part number? It would be most appreciated.
    Newbie jessb_55 is a glorious beacon of light
    Jul 2009
    Default same
    hey, I'm in the same situation, did you figure anything out? Thanks!
    Master Mechanic Crakums_GT is a glorious beacon of light
    Jan 2009
    Minot, ND
    Have you tried talking to the dealer? I know when I bought my after market head unit I also had to buy the adapter for XM as well as the subscription. If you hit the XM button does it at least give you channel 1? IF so then you have the components and just need the subscription. If not then you'll need an adapter which can run from about $40 to $75 depending on type of vehicle and an antenna. For my silverado it was about $50 and plugged right up to the back of the unit. I would definitely talk to a dealer though and see what they have to say.
    -Greg
    The fool learns not from the wise man, but the wise man from the fool.
    2004 Silverado 4x4 (Suzie)
    6" Fabtech Suspension Lift
    35" NITTO Terra Grapplers
    18" MB Wheels Predators
    Thrush Turbo Series Mufflers
    on true dual exhaust
    Grille by Option Racing
    1952 3600
    Finally getting torn down to the frame.
    Master Mechanic tattooed4life is a splendid one to behold
    Apr 2008
    Stevensville MI
    My parents have an 06 equinox and there appears to be no other parts than the radio. They do have a subscription and use it. I asked my dad and as far as he new it was all internal on the radio, you just have to activate the service. Check your manual it may have more info or you may need something else that he's overlooking in his equinox.
    1997 Chevy K3500
    4x4 X-Cab Dually
    454 Dual Exhaust
  5. #5
    Jul 2009
    hey thanks for the suggestions! Well I ended up going with an ipod interface instead, but it plugs into the xm input of the radio? Someone told me it was in the left rear panel of my equinox, but I didn't see it. Does anyone if it's on the back of the headunit itself? Thanks
Similar Threads
  1. 05 Avalanche - radio lights don't work at night [Expired Topic]
    By lakebear99 in forum Chevy Avalanche Forum (Escalade EXT)
    Last Post: 03-05-2009, 09:11 AM
  2. No Radio Illumination [Expired Topic]
    By BINGO53 in forum Chevy Equinox Forum (GMC Terrain)
    Last Post: 07-15-2007, 11:12 AM
  3. 94 suburban radio install [Expired Topic]
    By 94burb in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 12-31-2006, 04:25 PM
  4. Replacing Lights In The Radio [Expired Topic]
    By udderchaos in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 08-22-2006, 10:27 AM
  5. Radio Unlock Codes [Expired Topic]
    By Dr_Zero in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-08-2006, 02:14 PM
