Results 1 to 10 of 14
    Default 2004 Suburban new owner question.
    2004 Suburban LT 5.3 222K miles.
    Hi fellas just bought this Burban for only $3500. Interior is in great condition as well as the outside. This truck had two owners both brothers, one had it since new and the other for about 90K. The first owner had always put synthetic oil since new as well as the second owner who uses now Mobil high mileage 10W40.
    1: Sorry about my rant. What oil do you fellas recommend me using now? I want to keep this truck for a long time. Should I continue with synthetic or Dino since it's got high miles and what grade?
    2: Should I change the tranny fluid as well as filter?
    Thanks in advance.
    Nov 2011
    Central Illinois
    Here goes another oil debate!
    I like Mobile 1 5W30 but any 100% synthetic will do a fine job.
    I would do a trans service, diffs and t-case. If you can do the work yourself it will save you a crap ton of money.
    2012 Silverado 1500 LT 4X4
    2003 Suburban LT 2500 6.0L
    Thanks for the reply, I was not asking which oil was better or worse much less go into an oil debate. As I stated before the truck has been using Mobil high mileage 10w40 so should I continue using it or bring it down to 5w30 per manual or 10w30?
    Nov 2011
    Central Illinois
    What is your oil pressure when idling with the engine fully warmed up?
    What is your oil pressure at 1,500 rpm - 2,000 rpm with the engine fully warmed up?
    Does it burn any oil?
    Just bought it last week and I haven't used it much so I don't know if it's burning oil or not. I noticed fully warmed at idle the pressure is between 30 and 40 and when I accelerate obviously the pressure goes up to almost 40.
    I second the vote for mobile 1 5w-30. I will add, with a AC delco oil filter.
    that pressure seems a little low. My 2005 is just a tad below 40 at idle and goes almost up to 60 on accel.
    Nov 2011
    Central Illinois
    Pressure is good with the current oil. I wouldn't change a thing.
    My guess is that with 5W30 synthetic you will see pressures above 40psi under acceleration.
    Owner changed the oil about 4k before I bought last week and made a 20hr round trip from Denton, TX to Corpus Christi, TX? Is it possible that since the oil is not fresh it's reading low pressure?
    I forgot to mention that the previous owner has been using The Mobil "High Mileage" 10W40. So keep using it with an AC Delco filter?
    Quote Originally Posted by paracutin View Post
    Nov 2011
    Central Illinois
    Like I said earlier, I prefer Mobile 1 5W30.
    Your truck has been using Mobile High Mileage 10W40 for the last 90,000 miles. You have decent oil pressure. Why change now?
    If you really want to know what's going on inside your engine have a Used Oil Analysis done. You can read all about it here. http://www.blackstone-labs.com/
    Without tearing the motor down that's the only way to tell the condition of the internals.
    Same here. I have 185k miles on my 2001. Oil pressure at idle is 40psi and cruising at 2000 rpm at 60 psi.
    It has only seen Mobil 1 5W-30 since new.
    1993 964
    1996 318TI
