you'll be fine with spacers. They do no more damage than wheels with negative offset. If you go with wide enough spacers that they come with lugs in the spacer itself, then you MIGHT have to cut your studs down so the wheel will sit flush on the spacer. Make sure to torque them abs recheck the torque until you are comfortable knowing they aren't going anywhere.
